kingOFgEEEks
- 12:37 AM
- Feb 9, 2016
- Tioga County, PA
I like not having to worry which breakers are turned on while the generator is running.
Did you drain old gas out the fuel bowl and tank? My grandpa has an old one like that and iv had to dra8n old fuel and ran perfect.I was given an old Briggs generator that won’t run. I am not familiar with these two needle carbs. It seemed to have good fire and I was able to get it to hit a couple times. Here’s a pic of a carb like it has. Any info would be appreciated or trouble shooting tips.
Drained gas. Tried gas in plug hole and just back fired. Took carb off and cleaned. Now it’s flooding a lot. Maybe float? Tried to leave everything adjusted as it was but maybe I bent somthing.Did you drain old gas out the fuel bowl and tank? My grandpa has an old one like that and iv had to dra8n old fuel and ran perfect.
If that dont work try spraying gas in carb to see if it fires. If so maybe clean carb.
Fuel shut off turned on?
Id check float, needle valve and seat if its floodimg bad.Drained gas. Tried gas in plug hole and just back fired. Took carb off and cleaned. Now it’s flooding a lot. Maybe float? Tried to leave everything adjusted as it was but maybe I bent somthing.
Well i just upgraded my generator. All excited and cant wait to try it. Hoping this should run all i need and more.
What kind of generators do you run.![]()
Intresting. I thought it would run a dryer no problem....I have the same one. Had it since approx. 2012. It does a good job. I once tried to run the washer and dryer. Washer wasn't happy and dryer popped the onboard breaker![]()
Been there, dun that. You must be at the end of the line like I am.Yamaha YG6600DE for the house and Yamaha EF2800i for the fifth wheel. 6600 has run 1-6 days at a time, too many times.
Great info. ThanksThat is the old 2 piece medium flojet carb. Upper right needle is idle mixture. Lower left is high speed. Original carbs had metal tipped needle. Some rebuild kits have viton tipped needle. You need to make sure the seat matches the needle or it will never seat properly. You can buy a new China carb on ebay for $15. Will need to modify the air cleaner. Search on Briggs medium flowjet. Rebuild kit runs around $10. Since you said you cleaned it you figured out how to separate it without breaking the fuel nozzle tube. Take out the high speed needle and use a flat blade to remove the nozzle tube then take the 4 screws out.
