- 4:28 PM
- Dec 29, 2015
- Strong Island NY
I'm having a strange hesitation issue with an 024-026 conversion.
The saw is ported. Comp currently 230 and timing advanced 6*. Brand new WT194 with the metering lever set .020 above the factory setting. Saw has passed pressure and vac test. Brand new OEM fuel line and filter.
The saw runs like a beast with no hesitation at all from idle to WFO initially. Let the saw keep idling for a bit,
and the idle rpm's drop slightly. Then pull the trigger and the saw wants to die. Get the revs up, and it runs fine again with no hesitation. Let it sit idling and it repeats itself.
My guesses are that the saw gets hot at idle and cools down after a few revs. I'm also wondering if my metering lever adjustment may be causing the saw to start flooding at idle and then get a sudden dump of fuel. I've run the metering lever above flush on a few ported 026 and it's generally helped performance.
Thanks.
@Terry Syd ?
Thanks.
@Terry Syd ?
