OEM 372 cases and compatibility
magicrat
1:29 PM
San Antonio tx
So I was looking at the OEM cases for a Husqvarna 372 on HL Supply website. Does anyone know if both an X-Torq and Non-Xtorq piston and cylinder will go on it ?? Also will Jonsered oem plastics go on it just like a Husky ? I’ve heard that the cases between a 372 and 2172 are the same. But the plastics r not interchangeable. I’m guessing they fit together differently ?
farminkarman
I like the red & black ones
1:29 PM
Neenah Wisconsin
You can’t run an x-torque top end on oe cases, but you can run an oe top end on x-torque cases. That being said, you should be able to run either top end on 2166/2172 cases or the 365/372xt cases. Not sure on the plastics as I haven’t tried.
magicrat
1:29 PM
San Antonio tx
Ok thanks. The cases at HLSupply are 365/372xt. I assume they are the current cases Husqvarna is using rn ??
farminkarman
1:29 PM
Neenah Wisconsin
I would assume so…HL supply has IPL’s for a lot of saws…you could check the IPl for the XT model and see what pn it should be.
Duce
2:29 PM
Roscommon, MI
It is possible to run an X-torq cylinder on oe cases if you grind small amount of case allowing cylinder to mate with case. Can be done with dremel and easy to do.
2:29 PM
Yes
magicrat
1:29 PM
San Antonio tx
Good to know. I believe these are new X-Torq cases so they should accept anything. Finding an OE case in excellent condition can be tough.
qurotro
Cookie Cutter
1:29 PM
Ar
YES. But the newer production XT case has different oil output slot.
They stopped making OE cases when they introduce the XT. Even the OE from the other side of the planet which are still being made use XT case.
magicrat
1:29 PM
San Antonio tx
So would changing an X-Torq into an OE be as simple as changing the cylinder ??
qurotro
Cookie Cutter
1:29 PM
Ar
Yes, and no. The carb and intake boot is different also. Plastic are different but XT engine cover would work, but taller.
