Stihl working Hard
Is it Friday yet
- 9:42 PM
- Feb 6, 2016
- Perth Australia
What have you got in there Dave nice set up buddyStill cookingView attachment 248758
lol butthurt for dodge ? alot of the old dodges wouldnt run on anything else
I needs some help. Do any o you fellers know how to work on a Ferd? Never had to.
Can’t complain storms expected this afternoon thinking about lighting the fire .How was your dayHow you doin Todd?
Do you just abandon them too?I needs some help. Do any o you fellers know how to work on a Ferd? Never had to.
Naw. Just drives em. Parked between a Chebby and a Dirge yesterday, and I think it may have got some sorta infuction. It was running fine til then.My old tt500
I got something up my sleeve for some folks that want to try Denso parts at the GTG. We make a lot more than plugs. Stay tuned...I've probably got denso and ngk plugs older than you are. Champion plugs haven't been gooder for awhile. Open them ears and close that mouth you might learn somethin from all the experience in just this thread.![]()
im ok coffee timeDoing ok dall how was your day
if you take the blue oval off the front it helps gets people to help work on itI needs some help. Do any o you fellers know how to work on a Ferd? Never had to.
Is dat a YZ500 Yo mama?
Youre no help.im ok coffee time
hows you slacker
lol im ok coffee timeYoure no help.
I guess I could tie a bowtie on it and get plenty of folks to try to work on it.
Then the gas guage would quit working and I would start having problems with the motor. Maybe I'll just have a priest come in and cleanse the bad spirits from it.
I'm doing good slackomaniac.
Hows Maddie? And you?
Yep. Neither one of ours do either. A blanket tucked tight around her helps if it's not too hot.lol im ok coffee time
maddie is right beside me she doesnt like loud noises and they are letting off fireworks
whats going on with the ford
remember ford is job 1 what they dont say is its job 2 3 4 5 6 and 7
automatic ? ive seen torque converter bolts come loose and cause problemsYep. Neither one of ours do either. A blanket tucked tight around her helps if it's not too hot.
Was thinking something was going on with the torque converter months ago.
Would shudder under load. Thought maybe plug wire, but have changed those. Doesnt get driven much. Got a service truck. 194K, and the tranny hasn't been touched since ive had it. Shudder is probably torque converter.
Leak ive experienced today seems to be coming from the rear of the tranny, so maybe tail seal. Looks like it's between the trans and transfer case. Gonna pull it out as soon as I get the woodworking garbage out of the garage.
Good here Rodney.Evenin party animals. Braved up and took a bike ride over to Gettysburg today. Them pussy *f-wordtards that's causing all this *s-wordt were to show up. Well let's just say they were wise enough not to show. Huge police presence and probably enough hardware from local billhillies to redo the civil .war. made it home without losing any buddies this time, thank God. Just got dun watching fireworks wif momma.
Hope you all had a good 4th.....[emoji16]
I'll check that before I pull it.automatic ? ive seen torque converter bolts come loose and cause problems
could have a tight u joint as well
