NSP2. Cuz PA WiFi sucks
Status
Not open for further replies.
1:10 AM
1:10 AM
Idler pulley took a dump on my friends dodge
Nitro20200219_172607_HDR.jpgeasy fix20200219_163211.jpgstopped by my friends shop he got this 2020
250cc hawk made in china to fix
The guy spun the valve core off the rear tube.
Seems well built only has 30 miles on it
It was only 1400.00
D.o.t tires and no bead locks and not enough air caused the problem.
The only downside is the carb float bowl is riveted
He's going to drill them out to try different jets
In it
P.M.P.
Stiff Member
1:10 AM
Michigan
Factory track bar bolt doesn't fit right shoulder on it doesn't go up far enough.
Tried to find another bolt at Fastenal. Didn't have one. Decided to jb weld it shape the fugger.1582164165264352628512146170258.jpg
I had a sleeve from a seafoam can cut just right when I replaced the bushings last time. Thought this would be better.158216461965393309436350232099.jpg
Redneck backwoods Jerry rigit
P.M.P.
Stiff Member
1:10 AM
Michigan
Ordered a kit that was supposed to have bolts... Only got bushings and one of them is wrong bushing only able to use on end.
Sent me this kit instead
Track bar I got comes with bushings not as stiff as the other using one side for now to get it on the road.
Status
