Status
Not open for further replies.
dieselfitter
11:10 PM
MN
6011, the Honey Badger of welding rod
Mike and Joe would shake their heads at the rusty and dirty metal I have to weld on at times and the lack of "prep"
Rust, paint, galvanized will burn off. Who needs a grinder...
You would like 6010 even more, 40% more better.
I woke up to 1/2" snow in the yard this AM. It's melted off now.
Genius
First member of ASlite to receive a infraction
12:10 AM
Uncle Willys basement
We have about 6" here.
Went to the neighbors auction, it started snowing as soon as they got to the actual farm equipment which didn't interest me cause I wanted to come home to Lisa...
I ended up with about 50# of 3/8x1" bolts, a old school 1 gallon gas can, a bug zapper and a new bull float with two poles.
It started snowing, I said piss on it and worked in the shop. I rebuilt a 257 that I need to list on CL.
Red97
12:10 AM
MI
Looks good Joe
Thank you, didn't get any real clean pics of it fresh cut. They had already skidded the 4k steel block (bolster for the dies) in a few times, and had to polish the burrs off.
Glad it is finally done.
Had to explain to the customer that the mills were designed to cut .030-.050 off of an already flat surface. Not hog an inch and a half off in a few days...
Red97
12:10 AM
MI
You using a Mag-drill?
Got I hate them things, I had one let loose and come around and knock me off a ladder.
Yep, pucker is scary fo sho. Hydraulic. Run a 3.5" bit and tap 2" easy, gotta chain it down to tap 3" but it will do it :) Weighs Bout 350lbs..
In that pic I was finishing that hole, 2 1/8 x 24 7/8 deep.
Status
