usmcbuckwild
Buck
- 4:20 AM
- Dec 24, 2017
- NW CT
Evening fellas. 0 for 2 on the creamsickles tonight. 044 has an air leak... I suspect the flywheel side seal but ran out of desire to fug with it.
Will do budBrian, We will be playing at Doepke Park in Wausau. Look me up if you able to drop by.
I can't watch anymore vids tonite. Sweating like a mfr an tears running, ribs hurt. We're u guys find this sheeeeeit
Me swapped away a couple Huskies for a Stihl MS-201 mtron with rear handle, is that smart or not?
Question two, do it exist a rim sprocket system for that mini saw, or will I have to survive with the *s-wordty sprocket they have?
I know the MS241CM also comes with a spur but guys are converting those to a rim sprocket set up. Maybe the same parts would cross over.
Good morning Dave great pic my friendGood morning guy'sView attachment 134460
Good morning Jason hope your feeling better my friendMorning folks...72 heading to 92, another warm one!
Good morning Tor hope Norway is treating you well todayGood morning guys,
88°F, enjoy my first cup coffee.
We're supposed to set a new heat record in Norway, there are several places they belive it can be set in, old record is 95°F back from 1901![]()
No rim sprocket conversion is availible for the MS 201. The MS 241 rim sprocket can`t be used because the 201 has the clutch outside and the 241 inside. The 201 also uses a worm to drive the oil pump. That`s a different system as on the 241.
