Status
Not open for further replies.
2:03 PM
NW CT
I can't watch anymore vids tonite. Sweating like a mfr an tears running, ribs hurt. We're u guys find this sheeeeeit
Brother, those aren’t even the funny ones......... The funniest ones aren’t (kid/spouse) safe for this forum.
DND 9000
8:03 PM
Germany
Me swapped away a couple Huskies for a Stihl MS-201 mtron with rear handle, is that smart or not? :D
Question two, do it exist a rim sprocket system for that mini saw, or will I have to survive with the *s-wordty sprocket they have?
I know the MS241CM also comes with a spur but guys are converting those to a rim sprocket set up. Maybe the same parts would cross over.
No rim sprocket conversion is availible for the MS 201. The MS 241 rim sprocket can`t be used because the 201 has the clutch outside and the 241 inside. The 201 also uses a worm to drive the oil pump. That`s a different system as on the 241.
Tor R
Novice, Leg model #2
8:03 PM
Mandal
Good morning guys,
88°F, enjoy my first cup coffee.
We're supposed to set a new heat record in Norway, there are several places they belive it can be set in, old record is 95°F back from 1901 ;)
Stihl working Hard
Is it Friday yet
2:03 AM
Perth Australia
Good morning guys,
Good morning Tor hope Norway is treating you well today :D
GCJenks204
"Special Buns"
1:03 PM
Winnipeg, MB
Morning All / Evening Todd.
TGIF never felt so good, last day before 2 weeks off...
Thanks for letting us know, was just pondering outloud as to how others had solved a similar issue. Maybe next time I'll compare the IPL's before offering suggestions, but it is doubtful.
Status
