- 10:49 AM
- Jan 1, 2016
- Warren Center, PA
Ahh ha... hadn't tried the 4 jaw. [emoji106]4 jaw independent with duct tape around the piston to protect from marring
Blasphemer!![]()
1 pc of duct tape on the skirts and 3 or 4 on the window side or it'll dent the wrist pin openingsAhh ha... hadn't tried the 4 jaw. [emoji106]
My sorry.
All that was before my time so I have no idea what the rebellion was about.
Thanks I'll give it a whirl.1 pc of duct tape on the skirts and 3 or 4 on the window side or it'll dent the wrist pin openings
Was thinking of trying something like that. The set up time would definitely be less.I gots it.
Make sure you indicate both the circumference and the crownThanks I'll give it a whirl.
Ok.. I just got a indicator for the tailstock last week. Dang tooling adds up in a hurry.Make sure you indicate both the circumference and the crown
Mine is just a dial gauge on the end of a flex wand and a magnet. Chinese variety. Like $13 on ebayOk.. I just got a indicator for the tailstock last week. Dang tooling adds up in a hurry.
Yep I got one of those from harbor freight the other day.Mine is just a dial gauge on the end of a flex wand and a magnet. Chinese variety. Like $13 on ebay
I gots one too. I also keep an eye on the bay for old tooling, some of that stuff was made well enough your great grandchildren will still be using it after you're long gone. One oldie mounts in the tool holder and has a pointer with graduations in .001" only moves like ten thou, but is still accurate to measure deflection to this day.
I've picked up some good stuff from a local guy that was reasonable. The guy has loads of tooling and carbide.
I agree. For the most part, I only use them to indicate. Regardless of how accurate or inaccurate they are, if I can see a change, I know its not straight.I gots one too. I also keep an eye on the bay for old tooling, some of that stuff was made well enough your great grandchildren will still be using it after you're long gone. One oldie mounts in the tool holder and has a pointer with graduations in .001" only moves like ten thou, but is still accurate to measure deflection to this day.
And 99.9% of it isn't advertised for saleAbsolutely amazing what is lying around not being used.
Yep.Absolutely amazing what is lying around not being used.
I also use a Shars gauge that moves an inch and reads .001. The Asian reads in .01mm, which is .0004
