- 11:48 PM
- Dec 29, 2015
- Ontario, Canada
I think it's a safe bet that ol' GTG hoe will be hereIf Mike is coming to your gtg for sure, then I well definitely send it to you Kevin.
I'll be there. Might even show up earlyI think it's a safe bet that ol' GTG hoe will be here
i prefer my esting 16 ounce slag pick for destruction
Anytime buddy. Let me know when so I can get some pants onI'll be there. Might even show up early![]()
Lmao good one Mike.
Good evening Dave, how are you doing? When I get it tore down I will let you know if it needs a piston, and what size it is.If it's 45mm I've got a piston for it
It's either 44 or 45.View attachment 80350
Good evening Mike, how are you doing tonight? That saw will find it's way up north lol.
Pretty sure they're open port. Ditch the cylinder and replace it with a 346. You'll have a good little saw.I'm not sure, I haven't touched it yet. The recoil seems to have issues, but I will check it out before I hit ya up for it.
It's hot out here, but that's nothing new. You don't need to send me any money. I got the saw for free and don't mind shipping it.I'm good, dad and I cut some wood after work now I'm tinkering around in the shop. How's things in California this evening?
If you could Post your PayPal info. I'd appreciate it.
Brian said a 346 top end will go right on it. I will prolly have to get a different carb and boot, but I'm not sure.Pretty sure they're open port. Ditch the cylinder and replace it with a 346. You'll have a good little saw.
They should work. The boot is prone to tearing and you'll have to check for the dreaded plastic intake clamp.Brian said a 346 top end will go right on it. I will prolly have to get a different carb and boot, but I'm not sure.
Nope. It's all the same. I think a 2149 is a 351 or 353. Mag case semi pro saw with an open port cylinder. Put a 346 jug on it and it'll be a 346. Same carb and intakeBrian said a 346 top end will go right on it. I will prolly have to get a different carb and boot, but I'm not sure.
That's a good load of wood mike, and a cool truck.
Good info, thank you Kevin.Nope. It's all the same. I think a 2149 is a 351 or 353. Mag case semi pro saw with an open port cylinder. Put a 346 jug on it and it'll be a 346. Same carb and intake
Is there a metal clamp available DJ?They should work. The boot is prone to tearing and you'll have to check for the dreaded plastic intake clamp.
I use a 385/390 clamp on those.Is there a metal clamp available DJ?
