- 4:06 PM
- Feb 5, 2016
- grafton wv
morning kevin hows you
By now you should know better then to ever trust a fart. LolDJ farted?
Trying to get motivated. Failing miserablymorning kevin hows you
Me too. Got most of the crate put together til I can get the lathe on it and secure it. Going to need a couple strong back, weak minds. Got to go buy beer and see if I can bribe someTrying to get motivated. Failing miserably
Aluminum is best for cutting squish with. I used some plastic and some aluminum to cut bases. Wood mostly for sanding. 8-9" is best in the smaller lathes.Aluminum or plastic in the 2.25" to 2.50" range
think I can get by with as little as 9" or so I think.
I'm with you guys today.Me too. Got most of the crate put together til I can get the lathe on it and secure it. Going to need a couple strong back, weak minds. Got to go buy beer and see if I can bribe some![]()
zero is what you usually haveI'm with you guys today.
Is it actually possible to have less then zero ambition???
We call that "Neck down" workMe too. Got most of the crate put together til I can get the lathe on it and secure it. Going to need a couple strong back, weak minds. Got to go buy beer and see if I can bribe some![]()
I'm enjoumying this slacking. Might need to go grab some bullets from my neighbor and load some ammo.I'm with you guys today.
Unloading the ammo sounds like more fun to me.I'm enjoumying this slacking. Might need to go grab some bullets from my neighbor and load some ammo.
It's only a 9x20 right? Ought to only be 40 or 50 lbs lol.Yeah that's a good name for it.
Yep. Going to take it apart and put all I can in the boxes. Hopefully it will fit. In this crateIt's only a 9x20 right? Ought to only be 40 or 50 lbs lol.
I looked when I got mine. Same as yours. I think it's like 235 lbs. But you have a hundred lbs of extras
Good looking saw.Picked up a 1 owner 046 yesterday, pretty clean saw, he only used it sparingly, for firewood. Had not been use in years. It came with a 25" bar, and a few loops of chain, and some other misc saw related bull chit...
I didn't really need it, but it was calling my name...
lol take pictures we all know how @paragonbuilder dan is when comes to putting things together lolYep. Going to take it apart and put all I can in the boxes. Hopefully it will fit. In this crate
I might better. 2 bolts might be rough.lol take pictures we all know how @paragonbuilder dan is when comes to putting things together lol
