- 4:57 PM
- Feb 5, 2016
- grafton wv
i think they are all plastic mounted wonder if it is indexed right ?
Yes, oil pump is in plastic, I don't know about indexed, would it not just go in case one way?i think they are all plastic mounted wonder if it is indexed right ?
I really don't know, i'm just assuming it's in correctly, this guy is a good saw mechanic, that's why i'm not sure I could do much more than he has already done.there is a shoulder on the metal part of the pump it needs to be pointed to the outgoing tube
What keeps the pump housing from spinning in case?it will slide in at any position but wont feed unless the hole is close to the shoulder
OK that might be the problem, he just pushed it in and didn't align it.that i dont know unless a friction fit
you can use a screw to get it outOK that might be the problem, he just pushed it in and didn't align it.
The saw has to be completly disassembled ,cylinder out ,total tear down to get at it.you can use a screw to get it out
You got two running and oiling ?i cant remember its been 2 years since i messed with one lol do you want a couple ?
I don't need, but how much ya wanting for the best one?lol i had 4 of them i got 2 going and 2 others need carb and maybe a coil i think i short one
lol your addressI don't need, but how much ya wanting for the best one?
Sounds great Gary. You got a recipe?
Sounds like your trying to make some free space in your shop?lol your address
It's a shed. And yesSounds like your trying to make some free space in your shop?
