Status
Not open for further replies.
P.M.P.
Stiff Member
9:35 AM
Michigan
Lame pic's warning!!!
Damn still got a long way to go yet.......
13,000 lbs worth of welding wire. Alead have almost 3k layed.
350 lbs worth in that. Pita crawling in to do the far edge. at least I started on the largest one first.
Layers are important.. you can see the second cutout to be welded up on the other side of my arm.
Bastids already getting the next one ready. but it is a little fella, only be 2k ish of wire.
But they are adding sandwich "ovens" wrap lunch in foil place behind the door toasted In a few min :)
+Gfy
Joe what the hell are you welding? Thats alot of *f-wordkin wire
9:35 AM
Lol thanks Jon.
Kind of an oh chit moment.
Just glad this wasn't an oil soaked hoodie.. flamed up real quick like without help.
I like the insulated quilted flannel hoodies from Walmart. Get them on sale for $7-8. Sumbiches ain't for welding though. They look like sparks from Harry potter's wand if you get too close
Red97
9:35 AM
MI
2500 ton Forging press. The "puddle" will be roughly 20" thick at the back and about 8" at the front.42" wide 70" front to back. Some spots deeper, I'll take some pics once it get to em.
It is called a wedge pocket. In theroy you slide the wedge up/down to adjust the shut height for different die setups. I don't take long for the wedge to get beat down into the press bed, so when ya try to slide it the wedge sits on the high spots. Rocking back/fourth making bad parts. So fill it solid as have shims made for the different dies. lasts 2-4years vs 6-8months.
Red97
9:35 AM
MI
Just a plan cheap hoodie works best. Bout 2 weeks worth the arc rays burn em up if the spatter don't get em first.
Long sleeve turtle neck, hoodie, jeans and uninsulated car hart bibs is where I am most comfy.
Redfin
Meh...
9:35 AM
Central Pa
I think he meant running trunk lines to a few areas of the shop then tap off that Kevin. That's what I would do anyways. Running each plug and sw in its own pipe is definitely too much work in this case.
4/0 aluminum or 3/0 copper meets code for 200 amps
That is excactly what Im thinking. Good morning Men.
Status
