Status
Not open for further replies.
beaglebriar
The Peanut Gallery
6:48 PM
Warren Center, PA
Well, I got most of the yard work done. Still need to spray some round up. That might happen yet a little later tonight. As for my truck, I got my oil changed, everything greased, tie rod end changed and put on a new set of w/wipers. I was hoping to get my water pump done but I've just run out of time. Headed to the farm again in a few minutes.
What engine is it Mike?
6:48 PM
Got the 266 set up for poplar
24 with lgx skip.
Randy d suggested a more open exhaust on the barrels he ported.
I went a little more conservative
I'll screen it
Or it'll be a home for mud daubers.20170730_1441521.jpg 20180729_192454.jpg 20180729_191948.jpg
beaglebriar
The Peanut Gallery
6:48 PM
Warren Center, PA
beaglebriar
The Peanut Gallery
6:48 PM
Warren Center, PA
2005 5.7ltr Hemi. 260,000 kms and doesn't burn a drop of oil but this will be the second water pump I've had to put on it. I've had this truck for 12 years.
I have the same engine in my '06. Changed the water pump in a couple hours without pulling the radiator or shroud. It was a surprisingly simple swap. I was expecting an all day job. Lol
Canadian farm boy
“Normal” people scare me.
6:48 PM
Ontario, Canada
It shouldn't take to long to change it this time. I made sure to put anti-seize on everything when I did it the last time.
6:48 PM
I used to only buy parts at napa
4 bad alternators in a row
And a bad water pump for my 318 jeep grand
I started buying from AutoZone
Probably from the same vendors
But if you've ever changed one on a jeep
To put a bad new one on
Violence was on my mind
Status
