Stihl working Hard
Is it Friday yet
- 10:14 AM
- Feb 6, 2016
- Perth Australia
Good morning Mike how are you todayGood morning fellas.
Good evening Todd. I'm doing good so far. How was your day?Good morning Mike how are you today
Evening Todd...going good lately but don't say that chit too loud around here, everything liable to go to hell in a handbasket quick like! We got two more C-17's getting ready to get in the air and headed back to their home stations within the next couple of days. Hopefully no problems at Functional Test/engine runs/ops and avionics checks and they can get fueled and gone.Hi Jason how’s the Base treating you lately
Dam Gary that sucks but at least you know what the problem is.Well figured out what has been keeping me down lately.
Have a tooth that needs a root canal, specialist lost the referral so I have been waiting a month. The tooth is infected and that spread to my sinuses. Will pick up some antibiotics later and hopefully that gets me around the corner.
damn, that sucks.Well figured out what has been keeping me down lately.
As previously requested, sorry took so long (Chicken with head cut off syndrome) after refreshing my memory, it appears to be an original (not pretty)example for the most part, switch doesn't work or isn't connected. Cracked clutch cover, broken band. Hole in top cover. And appears to be a KS cyl,cases appear good. Forgot socket (but I had a T27?) so will try to get better pics including in ex. port.Somebody is supposed to take picture's
Of a 288 and send them to me
Oh yeah, AsIs Where is,No warranty implied,assumed or otherwise!As previously requested, sorry took so long (Chicken with head cut off syndrome) after refreshing my memory, it appears to be an original (not pretty)example for the most part, switch doesn't work or isn't connected. Cracked clutch cover, broken band. Hole in top cover. And appears to be a KS cyl,cases appear good. Forgot socket (but I had a T27?) so will try to get better pics including in ex. port.
These will have to suffice for the moment, but bad pics was getting dark and cleaning up tools before I realized I hadn't fulfilled my obligation, and was confident, you were calling me names...View attachment 109683 View attachment 109684 View attachment 109685 View attachment 109686
I'd be interested in one of those...if available. [emoji16]Oh yeah, AsIs Where is,No warranty implied,assumed or otherwise!
will get in touch later after chores are done did...
I will try... forgot to recalibrate my right foot for road conditions this morning.Hi DJ stay safe out there on the roads my friend
Hoarder!As previously requested, sorry took so long (Chicken with head cut off syndrome) after refreshing my memory, it appears to be an original (not pretty)example for the most part, switch doesn't work or isn't connected. Cracked clutch cover, broken band. Hole in top cover. And appears to be a KS cyl,cases appear good. Forgot socket (but I had a T27?) so will try to get better pics including in ex. port.
If you test one, will the price go up?Oh yeah, AsIs Where is,No warranty implied,assumed or otherwise!
FailAs previously requested, sorry took so long (Chicken with head cut off syndrome) after refreshing my memory, it appears to be an original (not pretty)example for the most part, switch doesn't work or isn't connected. Cracked clutch cover, broken band. Hole in top cover. And appears to be a KS cyl,cases appear good. Forgot socket (but I had a T27?) so will try to get better pics including in ex. port.
I found a nice 281 cylinder and a non decomp 288 those are funAs previously requested, sorry took so long (Chicken with head cut off syndrome) after refreshing my memory, it appears to be an original (not pretty)example for the most part, switch doesn't work or isn't connected. Cracked clutch cover, broken band. Hole in top cover. And appears to be a KS cyl,cases appear good. Forgot socket (but I had a T27?) so will try to get better pics including in ex. port.
Am not, promiscuity will get you cooties...Hoarder!
It wasn't there, had to drop some for my neighbor (he's going into kidney failure) couldn't remember anyway, due to stihl being in shock from climbing it to put a rope around that squirrels nest and jerk it outta the tree, so he wouldn't get hurt when I actually fellered the tree...Fail
It should be setting on the stump
Of a tree you dropped
Yes it appears that you have ample storage under those ears..I know what as is isView attachment 109691
