Status
Not open for further replies.
6:38 PM
Happen to remember what brand? And yes the windowed Meteor is the schnizzel in the 266.
Lrb. And there's a couple more on eBay. The lrb piston seemed fine, looked good, ran good, but I wanted to try a regular one. Glad I did
5:38 PM
Yeah used 5/8 threaded rod heated with a torch to bend.
If you're just going to run around the ranch at home this would be OK. There's no way I can mice words here to sugarcoat what needs said, so with this in mind...in no way shape or form would I recommend that for on Hyway usage. One good pot hole and your axle will be gone. Threaded rod is not heat treated and is very soft in comparison to U-bolts specifically made for the job at hand. My best recommendation to you would be to get the proper U-bolts from the parts store and replace them. Would really hate to see you get in some sort of accident because I didn't say anything. Hope you understand I'm not just trying to be a dick here.
5:38 PM
How much of a pop up (height) you cut on those 268 pistons?
Since Dave was putting them in a plethora of saws it was decided to just cut them at standard 372 piston height. Dave sent one along for an example.
That said if doing a one off, squish can be measured and the cut adjusted to reflect the new squish target measurement desired.
Cigmaker
6:38 PM
va
Just checking in fellas. I did buy the truck she ain't as clean as the pictures but it's decent considering it's 15 years old. Drove it 60 miles home nice and smooth. Need a new passenger side mirror and I hope a new battery in the remote everything else seems ok. Gonna get some sleep been a long day. I'll check in with yall in the morning.
Status
