Status
Not open for further replies.
1:03 AM
I imagine the abs will be unhappy and what about drive shafts? is the 205 a fixed yoke?
hoskvarna
1:03 AM
Iowa
A few years back I lost power in the winter. It wasn't a good feeling when my wood furnace was burning hot, no power and I had my generator in a out building.
It took a half hour to dig the generator out and then get it fired up.
My wood furnace was really really hot by the time I finally got power to it.
From that day on I keep my generator in my heated garage and I try to remember to start it about once a month.
Your supposed to load it also to keep polarity in generator.
Thats what I was told anyway.
Sent from Hoskvarna Hills
1:03 AM
Regardless what case I put in. Im just wondering if its gonna be worth pissin with the auto-trac to make it right?
Doesn't the auto trac more or less run off the abs? So Iam just thinking here but if you installed a manual front axle actuator then the manual tcase it should be good to go? Is it possible to pull the fuse for the abs if it causes a problem?
1:03 AM
Thanks Wayne. Im not sure how the auto-trac works. My main issue with this 246 is when Im using this truck it almost always has a trailer on it and Im sure thats why the tcase failed with only 115k on it. I just want a stronger case.
When I read a lil about that sounded common but the lil a read in that article made it sound like a easy switch
Status
