- 10:34 AM
- Jan 1, 2016
- Warren Center, PA
Morning. Rains coming in about an hour. I was getting worried hadn’t seen any in over a day.
Plenty of rain here today tooMorning. Rains coming in about an hour. I was getting worried hadn’t seen any in over a day.
Yeah....you have an ignition issue of some kind. Switch, or wires between trigger and coil maybe?Well here’s some gnarly pre-ignition pop:
ive had to crimp the connector that goes on spade terminal on trigger to get a good connectionWell here’s some gnarly pop. Pre-ignition?
Just found some wear spots and slipped some heat shrink over everything. Still popping afterward though.ive had to crimp the connector that goes on spade terminal on trigger to get a good connection
im talking about the one on the blue trigger under the top cover.Just found some wear spots and slipped some heat shrink over everything. Still popping afterward though.
WTF?
Looks promising, hammer it into place with the sledgehammer, Ed
When it is not them doing the work, it is real easy to just say "swap it out"...the manager just said to use the old banjo bolt because he didn't want to do any paperwork on it.
Check the ground on the firing coil.Just found some wear spots and slipped some heat shrink over everything. Still popping afterward though.
