John Wargo
3:47 PM
Pittsburgh PA
2:47 PM
stihl livin
Do the Dallas
2:47 PM
Upper Midwest
@stihl livin . When you door the plumber thing do you always leave the cast iron flush with the wall surface? And the plastic hubs sticking out beyond the plane of tthe studs. Asking for some Pittsburgh hacks. View attachment 460404
Looks like they missed the wall just a tad and said send it. Those 22s could have been offset lower and more into the wall so just a small portion would have been exposed. Sometimes you just got to let the wall board cover it up
AlfA01
10:47 PM
Evia, Greece
Good morning guys,
I got the Temu pliers yesterday, and got to use them.
The terminal is not a perfect match but was the maximum of what the pliers could do.
It will probably not be a problem as it is but I will solder so then it will be strong.
Happy Birthday @AlfA01
Thanks Tor!
Tor R
Novice, Leg model #2
9:47 PM
Mandal
The tractor's BusBar system is pretty much finished, now I just need to figure out where these two will be placed, the double one will be stripped to the positive wire at the battery, for the 4th station I need to find a place near where the relay module will end up.
