Slumberjack
Team OPE benchwarmer
4:07 PM
Way down south Louisiana
You sort the 6.7?
Pressure gets lifted. Pressure gets regulated. Pressure gets injected. Excess gets returned.
It's not rocket surgery.:D
Yea lol waiting on parts to come in lol. Supply to the cp3 is weak not even holding 10psi at idle
4:07 PM
You sort the 6.7?
Wrong! Excess is how compression is made, come on man, everybody knows that. Lol
SpaceBus
5:07 PM
Downeast Maine
HHO is unfortunate an energy carrier not a source. Takes more power to separate h2o into 2h2o2 commonly called hho or orthohydrogen. Would be neat if you could bottle the stuff and have wind power make it but you absolutely can’t bottle it unfortunately. The other option with it is a battery bank and you plug it in and is the batteries to make hh0 while you drive. But electric assist motors seem to be more effective in just burning less fuel. NOX is a result of high pressure combustion and or higher temperatures combustion. I don’t see a way around not having SCR NOX capturing equipment even if a vehicle ran just on hydrogen. The exhaust would be indeed carbon free. Nearly pure water but also Nitric oxides, nitrogen dioxide, nitrous oxide. All the reactive NOX that likes to suck up free O2. Meh who knows what we will have in 20-30 years
I wonder if it will ever be possible to get rid of the last 10% of NOx emissions? My stepdad had a 6.7 3500 SRW for towing the 5th wheel and never had an issue filling the SCR tank.
Slumberjack
4:07 PM
Methods of reducing NOX in boilers and burners for cooking oil for refining involves starving the fire for oxygen and manipulating air flow above burners to stretch the fire ball. So a larger colder fire ball makes less NOX. Since it’s produced by high temperature combustion in the presence of oxygen. In engines It’s not so simple. Cummins been playing the NOX particulate game since 1993 with the epa. Playing with injection Spray angles and timing. EPA wanted less soot. Ok tighter spray pattern and advance timing. Well that makes more NOX because it’s a higher cylinder pressure and therefore temperature. So they went to lowering cylinder pressure with pilot injection and ticketing the fire with multiple pulses per stroke instead of one big explosion. Man they gonna keep playing games a long time lol
GCJenks204
"Special Buns"
4:07 PM
Winnipeg, MB
