41FanForLife
- 11:28 PM
- Apr 23, 2020
- Don Martin's House
Good thing he didn't say clean and respectableWhy? I'm dependable.
Egg ZacheryGood thing he didn't say clean and respectable
All that matters.I was told it hits the spot so...
what was his name that said that ?I was told it hits the spot so...
You dik.what was his name that said that ?
lolYou dik.![]()
that sucksMy tractor is trying to piss me off.
Started it and moved it out the barn then it died.
Fuel filters clogged. I replaced them and noticed some black crud in the first one so i drained the fuel.
Found some black goo in the tank but the stuff won.t dissolve in fuel.
Now with everything clean i can't get fuel out thru the injector pump.
The batteries were weak and upon inspection found them to be 9yrs old. Time to spend money for new ones.
Now i need to bleed fuel thru everything again especially The injector pump.
I need the tractor to load the grain drill to plant wheat at the dove club.
Stuff only breaks when you need to use it.
doubtful lolGFY I'm straight
Black algae? There is a treatment I put in my bulk tank that prevents the stuff.My tractor is trying to piss me off.
So far that has not been my experience. Hopefully it never turns into that.Tractors are as bad as boats when it comes to spending money and time.
Same here. I use bioborBlack algae? There is a treatment I put in my bulk tank that prevents the stuff.
I always give my friends husband hellWife is pandemic buying again. She just dropped $360 bucks at Costco after grocery shopping on Saturday. Any of you run out of chit tickets stop on by. We're stocked to the rafters
