Woodwackr
2:04 PM
ID
There's been two drones flying around out here the last few nights, a few miles east of here, CO/NE border. 4 lights on each, they'll hover in one place for a few minutes then move around a little bit, but kinda stay in the same general place. They dont appear to be small drones .
There's literally nothing out here, but corn & wheat feilds, and old homestead abandoned farm houses every 4-6 miles. I wonder who's flying them or what they are checking out. It could be Skynet. Or the feds spying on some tweakers that have a lab in NE, it happened 4-5 years ago over there, when they busted up a ring.
So…get ya some of them new depleted Uranium 12g shells and have at it!
Tor R
Novice, Leg model #2
10:04 PM
Mandal
Good morning ladies and gentlemen,
Today I'm going for a little trip to the forest and dump the slaughter.
Now that my brain is starting to clear (not sure it will clear completely) I realized that I have a 339 xp project too. On the next order from MaskinSalg Evje I will order a cylinder gasket and new crank bearings, put it together and do the v&p (I will definitely have to make blocks for this too.
We will have a few days of strong wind, will be working indoors with chainsaws instead of in the forest with Øsa. Definitely 2-3 workouts too so that my stomach is in shape and gas production is at a high level.
Are there any of you who use electronic timing wheel? Pros and cons
Lnk
Stock Chainsaws do not suck!
4:04 PM
East, TN
Good morning men, raining and Sunday, may just be a Slack-fest today. Ordered some Ethiopian green coffee beans, I like the Guatamalan that I have, but love the yirgacheffe. Coffee time.
sawmikaze
4:04 PM
steeltown
I saw one last night, I can't say for sure how big it was because I know absolutely nothing about drones but I know it wasn't one of those little hobby things.
Member
3:04 PM
I have one, it is easy to read and takes a bit to set up correctly, I use a calculator. Saw needs to be in a vice that stays in the same plane as it is moved to see better, otherwise readings will be off the amount the saw tilted. I can only use mine on my tree monkey vice, the other ball socket stand I have needs to be used with a wheel to ensure it stays the same. Also, when going back to the project to check again, it needs to be re-zeroed, once you get used to this it can be done the first try if you do the math right.
Long and short of it, if you have a good saw vice, go for it, if you don't, either forget it, or get a new one from tree monkey, you'll get none better and you will wonder how you managed so long without it.
Tor R
10:04 PM
Mandal
Steve, Thanks for a good explanation, then I stick to the classic timing wheel.
beaglebriar
The Peanut Gallery
4:04 PM
Warren Center, PA
I’m hoping to see one here so I can get a real close look….
