Loony661
462’s 4-LIFE
11:02 AM
Winona County, MN
That’s the alps and very steep off the edge of the road
Slacker
What do you do spend all your time on *f-wordbutt ? lol
I’m fully aware. I’ve been to the mountains several times. No guardrails on the roads in the mountains - either stay in the road, or die. I love mountain roads.
Did you get your cable brake fixed?😁
Winch brake was never the problem. Drag is set just right.
12:02 PM
Wonkydonkey
Plastic member
5:02 PM
Sussex, UK.
Evening gazers. Got a couple deer chopped up tonight. This new vac sealer is pretty fukkìn sweet!View attachment 442790
That looks awesome.
can’t hide $$$ 😉
Feels like it has plenty and it ran perfect when parked.
I was going to say stale gas in carb. !
I try and run carbs dry if not using the machine for some time. That way hopefully you can run fresh fuel , however sometimes the crud in the carb dries and flakes off (varnish) and blocks the jet
Are the spark plugs even wet with fuel? Did you put gas in the cylinders to see if it will start? Try using compressed air too push fuel through the system. You cover the fuel tank opening and use an air nozzle to push the air into the tank which forces the system to prime. I’ve had to do this on my sleds but they are a battery less fuel injection
You have to go through all the bad fuel still inside the carburetor before it will start and run on new fuel.
Only the Tony
11:02 AM
Good morning men, happy Thursday. Looks like I need a root canal and a crown. Thank god for insurance, will only cost me 1800, cause the insurance will pay 700. Why did I buy insurance?
Might need to shop around for dentists. One I go to is almost always half the price as the one my wife uses on every procedure they do. I get setup for another crown in January, no root canal it looks like. Less than $1k and out of pocket is about $170.
redline4
I'm huge in Japan
11:02 AM
Rosholt Wisconsin
@redline4 Hey Ed, gotta tell ya another Chevrolet story I learned today. Woke up at the motel with a dead battery on the TrailBoss. Luckily a guy was good enough to give me a jump. So I stopped tonight and bought a jump box in case of rinse and repeat. So I'm sitting here looking out the motel and the parking lights flashed 4 times in sequence every 15min. Course I Loogled it. After tire air ups came back and parked it. Of course it is still doing 4 flashes in a sequence every 15min. I gonna go pull the battery cable right now. Any ideas or known issues? Thx man
Only time I've had that is with low tire pressures.
Your truck have a key or push button start?
redline4
I'm huge in Japan
11:02 AM
Rosholt Wisconsin
Riding the scooter to work?
If the roads weren't covered with salt, ice and snow.
Back when I had a sled I had no issues going out on that in weather like this.
I had on of the first gen modular helmets. Your air came in and out through 2 vents on the sides. Many times you'd be riding when you suddenly couldn't breathe as the vents would freeze. Had to stop, take the helmet off and chip out the ice.
11:02 AM
I did that not too long ago. Now I don't have that tooth anymore....
redline4
I'm huge in Japan
11:02 AM
Rosholt Wisconsin
Push button
We had a few complaints of trucks going dead overnight which all seemed be be caused by a failed over the air update. That was fixed as far as I know by the serial data gateway module program update recall.
The flashingights should have stopped once the tire pressures were up to spec.
What year is that? (I'll probably also need the 5th digit of the vin because we had the whole covid thing which resulted in some model year trucks being sold as the next model year..)
I'll dig around on my lunch hour to see if I can find anything on that happening.
11:02 AM
You're a good man Ed.
