redline4
I'm huge in Japan
- 10:04 PM
- Mar 12, 2018
- Rosholt Wisconsin
Hola cűnts.
What's the good word?
Fughin Chinese HEI distributor was the whole fughin problem. It's running great now.This boy's truck is gonna make me pull my damn hair out....
what’s next for the truck?Fughin Chinese HEI distributor was the whole fughin problem. It's running great now.
A lot of little things. Needs a fan shroud. The exhaust system is leaky. Power steering pump needs the mounts repaired. Winch fairlead has to be mounted. Etc....etc....what’s next for the truck?
I would if I had his number, !You'd need to ask Dallas. He told me not to bother texting him.
Dang the HEI is good if built properly.Fughin Chinese HEI distributor was the whole fughin problem. It's running great now.
What's your water temperature ? Ours is about 78°Evening bishes….just crawled my fat ass outta the pool.
Sitting at 82 tonight. It’s really climbed this week, I wanna say it was 76 last night.What's your water temperature ? Ours is about 78°
I don't mind an HEI....but this Chinese one just wasn't right at all.Dang the HEI is good if built properly.
I think i still have 1 or2 built that we used in the racecar.
Real bearings and a good stable advance curve.
Chevy used to have an upgraded chip for them that worked up to 7k
Magsrus , Mags r us built a good one years ago as well as racing mags. He also had a good chip for the 1 wire HEI
Jacobs racing wires were a good source for make yourself wires.
Now you know as much as i do, consider yourself special.
When the bushings are true and snug they don't spark scatter and keep a good strong spark.I don't mind an HEI....but this Chinese one just wasn't right at all.
Thats just the crown of the road bein too tall, nothin to worry about.So one of the brand new apprentices comes back in the school after dismissal and says i have a flat tire. Couple of us went out to help him out. Didn't expect to see this. Maybe @redline4 homies could help him out with a alignment?View attachment 423492
Lifted Squarebody Chevy. .040 over 350 with 041 heads.When the bushings are true and snug they don't spark scatter and keep a good strong spark.
The brain/chip is the trick. Depending on intended RPM you can use one of three GM chips
Aftermarket chips were a gamble but i would think they would be better compared to the ones from 20+ years ago.
Is this a truck/work motor or a fun motor?
