Lnk
Stock Chainsaws do not suck!
- 2:06 PM
- Oct 12, 2021
- East, TN
I have to go to Crossville, how is the weather your way @Mastermind ?Good morning men.
Just wet. Really wet.I have to go to Crossville, how is the weather your way @Mastermind ?
Near the intersection of 127 and 62 in Clarkrange, the road was washed out last night. I'm hearing that it's been repaired now and traffic is able to get through. We had a hell of a lot of rain.We are still having thunderstorms, don't want to play in those.
On older brake systems i have seen the flexable hose going to the rearend delaminate inside. When brakes are applied the liner inside collapses stopping fluid flow. If you pressed brakes slowly fluid would sometimes flow. Press them quick/normally and no flow.Yes. I had him to gravity bleed it. Made sure the proportioning valve wasn't tripped, opened the bleeders on the rear, and walked away. It took a few hours, but sure enough it started dripping fluid. After that it had pressure and was able to be bled.
All lines are new. As is the master cylinder, proportioning valve, wheel cylinders, etc.On older brake systems i have seen the flexable hose going to the rearend delaminate inside. When brakes are applied the liner inside collapses stopping fluid flow. If you pressed brakes slowly fluid would sometimes flow. Press them quick/normally and no flow.
Cars have more parts than chainsaws that cause even more problems.
Got an old Stihl on a chain you can toss out the window fer emergencies and such like @dall ? Always ready for anything that guy.All lines are new. As is the master cylinder, proportioning valve, wheel cylinders, etc.
