11:37 AM
Because it’s stupid whatever brand of vehicle it is should have that brand of engine. 460 swap into a bull nose won’t be that hard and I bet Randy has a parts truck with everything there
I had a 51 Ford F1 that I SBC swapped.....and a Fox Body Mustang......and a Chevy Luv. LOL
And.....I've just finished building a hot SBC for a 87 Dodge Dakota that I have.
But......when it comes to big block engines, I prefer the Ford engines.
12:37 PM
Chevy makes big blocks also
Firewood Hoarder
Just a firewood hack
11:37 AM
Wisconsin
I like the 385 series Ford engines.....
Probably a near direct fit to replace the 7.3? I'd assume the bellhousing and motor mounts have to be about the same.
Personally, I have a soft spot for the 300 six. It won't get you there fast, but it'll get you there.
11:37 AM
Bellhousing is different, but I have one to go with it.
maulhead
10:37 AM
Home
If you can find a tiller, they are worth the money behind a compact tractor. I tried a 2 bottom behind my rig and didn't have enough traction even with 300lbs of rocks in the loader bucket.
I have a 50" bush hog branded tiller I use behind my LS mt125, and I have had no troubles turning over anything. Ive tilled plowed farmland that was mostly clay, virgin praire that had just been brush hogged, grass and sod that hadnt been farmed in 30 years... and it works awesome. Only thing that will stop it is a softball sized rock, which locks it up and then the driveshaft slipper clutch will do its thing.
I like a big bush also.... even better when it ain't been plowed yet.
