nbbt
12:15 PM
5543X, 5644X
Fugg I’ve been reading 16 pages of,… stuff I shouda skipped 🥱
Good afternoon boys, I went shopping at 6am this morning 100 drive & 100 miles back 🤨. and this came home with me 🧐
I’ve played with it.
It’s a bit slow but works. More info will follow as I unravel it history etc.
Can you roll logs on with a cant hook?
Junk Meister
12:15 PM
Nebraska
The way you worded/phrased your comment I was thinking a Pup or Dog ..
Not to let a good thought go to waste didja let it ride in the front seat with ya on the way home??
Looks like a smaller cylinder does it have a fairly fast cycle time? Might be a good cook stove/kindlin' maker, or small splits for smoker wood (just a few Thoughts)
Wonkydonkey
Plastic member
6:15 PM
Sussex, UK.
it’s only 8” off the ground, there are many possibilities ie a ramp and roll logs on etc 🤔😉
I could even mount it (leave it) on a trailer.
I think I found the manual for it.
I was thinking/wondering what size (output) pump it has on it. Manual just give a part no
I see the pulleys are similar in size (on engine & pump)
I have a 6.5 hp tecumseh engine I could put on it (if it fits), it'd have more power but the pump/ram speed would still be the same.
I will see what an be done, Ie see if I can change the pulley around , but I think I,m correct when I say a hydraulic pump is only designed to run at 3.5 rpm ?
Wonkydonkey
Plastic member
6:15 PM
Sussex, UK.
15sec from back to the front, slower if the 3.5hp b&so is not at full speed
It will be fine for what I want it for, but I just need to speed up the cycle time.
Btw, it rode in the the back of the truck on the way home 🤠
Junk Meister
12:15 PM
Nebraska
you would be ok with a guy sucking dick
you just have that look
giving or getting is the part i havent figured out yet
what did he say
Must be reading things WRONG, I Am ciphering some sort of pick up lines .... CARRY ON I Hear my Momma callin'
You need moar lube for your 🫦
what did he say
Gullet
12:15 PM
Arkansas
where does sore lips like fishing or snagging fish trolling go to needing more lube
so that leads me to believe he would be a round mouth
I'm not sure anyone understood which pair of your lips were sore?
Hope this clears up any confusion.😁
1:15 PM
even last night i said you guys had sore lips from being trolled
then he says that today so he is the one who is *f-worded in the head 2 totally different things
  • Like
Reactions: Lnk
