8:07 PM
Since we’re whining, my back hurt too, until I took a wood chip to the eyeball about 20 minutes ago - now my back feels fine.
Check up today. Sugar is borderline. Blood pressure is too high. Xrays on back shows old fractures, but no odd joint spacing. Doc said I was being a whiner, and to just suck it up.
JoeDirt
Piss Jug Tosser
9:07 PM
United States
We started our day at 0c and may hit 7c. Yes, I used the metric as is what world does 32 make more sense than 0 to define the same thing?
Both Fahrenheit and Celsius have long, weird histories and I could go on ad astra with it.
Two day to day advantages to Fahrenheit. One is you don't need to incorporate negative numbers into temperatures that you regularly encounter. No negative numbers equals easier math. 0 Fahrenheit is cold to touch, 100 is warm, 200 is too hot to touch. Easy. Two is that Fahrenheit is more accurate without using fractions or decimals. 180 degrees between boiling and freezing in Fahrenheit. Only 100 with Celsius. That's almost twice as accurate using only whole numbers.
Kelvin is the ultimate system for measuring temperature. There are no negatives. It is scientifically correct. There is no such thing as cold, only lack of heat and only the Kelvin scale acknowledges this.
And it is not a real metric unit, the SI copy and pasted it in 1954 when they realized how stupid Celsius is and then pretended like it was theirs all along, akin to claiming ownership of the moon.
9:07 PM
X-rays won’t show soft stuff such as the discs or ruptures of the discs
You’d need a mri or cat scan for that
Bilge Rat
9:07 PM
savannah georgia
I got a pain at my lower left rib in the front and a pain along the same rib in the back. Like the rib is out of place.
The pain feels close to the surface, no deep pain. It doesn't hurt to breathe.
Could these pains be aggravated by cold weather and old age or just old age?
JugHead27
I'd rather be called gay
10:07 PM
NS
I’ve been having mid back pain after sleeping a couple hours every night, a new kind of pain, not bothered at all during day but after I try to sleep wakes me up throbbing pain, goes away after I sit up for 20 minutes
Been going on for 5 months, has effected my sleep overall for sure.
Loony661
462’s 4-LIFE
8:07 PM
Winona County, MN
Have you been to a chiropractor? I get adjusted every 3 weeks or so and it helps me sleep better for sure. I can tell when my back/neck is out because I start tossing and turning at night.
8:07 PM
Fughin pussies. Walk it off.
