nbbt
9:25 PM
5543X, 5644X
They are following your plantings, noting where the fresh soft tops are for later munching.
Morning men
So, there's this...
After all, you were just showing off your studded snow tires.
I am what I eat...
When I left for work a section of our road was starting to crumble and there was over a foot of water in the ditch. Took an extra 40 minutes (almost double my normal drive time) to get in.
If you hadn't taken in that extra hour of sleep, or whatever.. You may have made it on-time...
JugHead27
I'd rather be called gay
11:25 PM
NS
They’ve been in the area they’ve been up to the same areas before the fire. Then little basturds tree slaughtering machines they better be careful lol
This winter will be the toughest on the seedlings as after fire there is still a bit of scarcity amongst food/vegetation and then they’ll see that nice pine seedling, next spring so many things will pop off and grow in not gonna worry about deer no more but rather competing vegetation such as stump suckers and other softwoods such as balsam
Loony661
462’s 4-LIFE
9:25 PM
Winona County, MN
Bet your glad that cold weld slug didn't break off and run through the hydraulic system LOL.
Absolutely! After I cut the weld at the nut with my cutoff wheel, I just smacked the rest of the weld with a hammer and chisel and it popped right off..
