Tor R
Novice, Leg model #2
10:07 AM
Mandal
Good evening guys / sprint lovers,
In a couple hours from now, that will be 3 weeks cig free, well, without the pin!
Walking around with the hearth monitor thing, we’re driving for delivery tomorrow morning. Next dr appointment is 18th october, but I’ll try to get the cardiolog to send me a msg before that. For some odd reason I’m on a good day, quite typhical when we’re doing tests.
redline4
I'm huge in Japan
3:07 AM
Rosholt Wisconsin
@Mastermind At a quick glance, it looks like all the inputs on your Ford go to the ECM from the respective sensors, then than info is sent to the cluster and specific circuits.
You could leave the original ECM and simply adapt the Ford coolant and oil sensors or swap connectors.
The tach and vehicle speed inputs will be trickier as I'd have to figure out the reluctor tooth count, because if they are different, it's going to read differently. The tach on the Ford reads off a crank sensor, the GM in that era will use it off the cam..so, some type of converter box will likely be required.
4:07 AM
I've found it difficult to get banned from the sprint fb page Tor
I'll try harder
4:07 AM
4:07 AM
Maybe. I'm not exactly on good enough terms with most of the staff over there to ask. Except Jerry, and I wouldn't ask him.
I got banned twice there first time for telling @Marshy and Darin over there where they could go when randy was being screwed over
Second time was when Imadik was trolling fabz and I was being myself
cuinrearview
Handy dood
4:07 AM
Dowling, MI
I bet you can't get a hat trick. No bannings unless you rip someone off in the trading post. But even then you have to get caught red-handed.
4:07 AM
