- 11:11 AM
- Feb 23, 2023
- Montana
You use a diamond ball burr
Ball hones are great for 4-stroke engines…not so good for a cylinder with ports in the walls like a 2-stroke.
Thats what I use to put the beval on the ports.
I understand I am not as knowledgeable or experienced as you all here. I appreciate the feedback. I do know why some say they are no good in engines with ports in the walls. I have as far as I know, never had a problem doing it. Maybe it's because I don't spend much time in it. Less then 10 seconds and with lots of oil, plus in nikasil or chrome bores I use a finner grit. I not there to remove material just clean up what's there.
I have not had a problem with losing material around the ports using a ball hone. I might be wrong, but before a ball hone removed the coating in the bore it would be ate up. In order to actually hone or put a new cross hatch in nikasil you need a diamond hone.honing will erase much more plating all around the ports than just putting a little bevel on port edges.
Not trying to be a noob that's a jerk . Sorry if I'm coming across that way. I would like to see some information on those who have done it and had problems.
I am here to learn. And of that means changing how I have always done it, so be it.
EDIT: The only thing I can see with the ball hone is if you get carried away and spin to fast you might chip the nikasil coating on the side of the port in the direction the hone is spinning. If that's the case, and if it truly chips the coating on the port edge. ( I have not seen it yet, but have never used a magnifieing glass to look) Then it's not a good idea at all no matter how "careful" I am.
