1:37 AM
Here you go. They are insulated garage door panels. A guy a few towns over has a contract with the manufacturer and sells they're seconds. They used to be dirt cheap.... not so much now. Still cheaper than metal roofing and much easier to install by yourself. How've you been Randy?
That looks like a fine ceiling right there.
I'm good. A little bummed out, but good.
hoskvarna
1:37 AM
Iowa
The 7.3 didn't start. Changed oil, fuel filter, flushed fuel system. Spun over pretty good at first....but seemed to be getting tighter over time. Pulling the glow plugs next to soak it in tranny fluids and acetone.
Spray some ether in it [emoji2960]lol
Sent from the Hoskey Hills
redline4
I'm huge in Japan
1:37 AM
Rosholt Wisconsin
We gave it a little whiff. No help.
There's a good chance your getting a voltage drop across the old cables, old grounds, even the starter..
Wouldn't hurt to "patch" in a couple grounds with jumper cables. Battery to block, block to chassis, chassis to battery.
May help to get it turning over a bit quicker.
beaglebriar
The Peanut Gallery
2:37 AM
Warren Center, PA
My buddy had a old Ford 460 that ate starters like hard candy until he did just what you said.
1:37 AM
glow plugs working ?
No.
oil pump good?
Probably?
Maybe a quick Cummins swap would help??;)
Not a bad idea. At least the transmission might last more than an hour.
Good idea Ed. Thank you.
cus_deluxe
terms of service violator
2:37 AM
Michigan
No.
Probably?
maybe im thinkin of the wrong thing, but i thought those needed good oil pressure in order to inject fuel. buddy had a 7.3 that would start to run like chit when the oil got just a touch low.
2:37 AM
Hey on a bright note I get to celebrate MLK day tomorrow all by muhself!!
Mines holding up pretty good but I only haul fairy dust and unicorn farts.
typical dodge owner with mirrors extended all the way out lol
i think you are right
redline4
I'm huge in Japan
1:37 AM
Rosholt Wisconsin
The 7.3idi was an indirect injection diesel. Ford/IH-Navistar thing, pre "Powerstroke" days.
The newer 7.3 powerstroke used an hpop system, High pressure oil pump, to fire the injectors.
