Hinerman
5:01 AM
NE OK
But failed......cause you is a slacker.
Truth...
I posted this in the "What's on your bench" thread to:
Can you or anybody else recommend a carburetor for an echo 225 motor?
I would like something fully adjustable if there is an option for that. I don't mind aftermarket, if you know of a specific brand.
Thanks in advance...
5:01 AM
Truth...
What the hell is an Echo 225?
Hinerman
5:01 AM
NE OK
I thought it is a Trimmer.
Googled; maybe this: https://www.echo-usa.com/trimmers-brushcutters/srm-225
LOL, Echo refers to a line of equipment, with their legendary 21.2cc motor, with the 225 designation. For instance, SRM-225 (straight shaft trimmer), GT-225 (curved shaft trimmer), PE-225 (edger), SHC-225 (hedge clippers), etc. They all have the same motor/powerhead. Solid motor, crappy non-adjustable carburetor.
I am looking for a replacement, preferably fully adjustable, if there is such a thing. The OEM carburetor is trash IMO. I will never buy another piece of Echo equipment with the non-adjustable carb.
5:01 AM
Should Echo, and Legendary be used in the same sentence? :camper:
6:01 AM
rotary carb? some have adjustment on top of the rotor for low side then one on the side hidden in a hole for the high side
im not a fan of the rotary carbs either
Hinerman
5:01 AM
NE OK
I am guessing that is what it is. They are not really adjustable, total garbage. Unfortunately, there does not seem to be an adequate replacement.
6:01 AM
i have a early 2000s model cub cadet 3000 which is identical to the newer echos so i know what you are saying
  • Like
Reactions: Lnk
timg
6:01 AM
Keystone State West
The older GT2100 used a conventional diaphram carburetor with H&L adjustments. The GT2101 updated to the rotary POS. Hope this helps just a little from a fellow Kioritz liker of orange LOL!:abrazo:
BTW, If you can find an old parts machine it may help with the throttle cable stuffs.
timg
6:01 AM
Keystone State West
Last 18 hours been extra brand hoey in here. I blame @dall
Since I haven't seen it mentioned: y'all are just chasin' your tails until you start using red equipment. Also teal=red
When I see the J Reds anymore it all about those Green////Backs Timbo.
