ayoungtexan
I tell a lot of lies
- 4:10 PM
- Apr 15, 2020
- Dallas, Texas
You think that’s bad you should see my phonecharge your phone slacker
Appreciate that. I'm making it up as I go along![]()
still scrawny lol
Still huge in Japan at that age?
You got it going on. Just block it up at the rear of the doors as well if possible. I worked with a guy for a while that was really good at that stuff. I tried to learn all I could. I enjoy that sort of thing.
lol nopeyou jealous cause your still chubby and bald?
Just bolt a box tube brace into your upper front seat belt anchor point. Slice open a square tube and drill a hole in it. No welding required there. Bolt on the tubing so it's going straight down to your bottom cross brace near the corner you made up with boxed tubes, weld it. Then put a top to bottom cross support or an X brace. Triangles keep things rigid and square. Check the doors fit up before you pull out your frame. Hang the doors back on to double check the fit when you tack the floor pan in. Make sure the door seals are in place.I need pictures... got a way to draw on photos?
I'm already planning on adding a brace where the yellow line is to prevent any parallelogram action from happening.
View attachment 257304 View attachment 257305
No need for that in your case but it won't hurt none.I need pictures... got a way to draw on photos?
it shouldnt move side to side with the angle braces he has in thereIt will look like the makings of a standard roll bar without the top cross tube. You need to keep the car square inside from side to side. Your concerned with front to back. I'm taking about side to side if that helps.
im not sure if he is gonna cut the outer rockers off or not
he said he use to do body work so im sure he has some knowledge of measuring the body of the car
lol need a second opinion ? lolKenny has a tough time explaining himself without confusing the ever lovin fuk outta the person reading along. So....some time ago, I began to stop reading along. Moar better is my brain now.
Is this an old massy?
the braces front to back and side to side will keep it from bowingIf he cuts out the inner rockers the outers now have no support. It will bow out sometimes from the roof weight pushing down. If it does you skew the area where the quarters come into the door jam. I *frenched up a few cars. Fitting *s-word up after the fact sucks. More bracing is betterer. Fitting doors to a slightly out of whack door jams really SUCKS!
ill take the blame lolOuter rockers are gonna stay on... probably. Most everything in between will be cut out. I've done a lot of patchwork and refinishing so I'm not afraid to start chopping metal out and I'm definitely not flying blind, but this isn't an afternoon job so I'm always glad to hear ideas from other people who have done it. I'm only lifting it straight up, not trying to turn it on its side or upside down or anything.
I don't think it has much of a way to move side to side with the existing braces and the spots that were reinforced from the factory.
But if it twists itself into a pretzel, I'll blame @dall.
Lmfao![]()
