- 11:44 AM
- Jan 17, 2016
- Wv
Did you climb it?Another 039 confirmed kill. View attachment 299275
If you keep doing tree work for friends John, you're going to have a lot of friends.Another 039 confirmed kill. View attachment 299275
That 039 weighs as much as that 288Another 039 confirmed kill. View attachment 299275
So from an anchoring point of view you reckon pretty similar Dave? Thoughts @dall?That 039 weighs as much as that 288
This is actually a really good friend of mine who happens to have a two-post lift in his garage so it's good to be in good graces with himIf you keep doing tree work for friends John, you're going to have a lot of friends.
NoDid you climb it?
The picture say something to the contrary.According to the saw gurus, the 039 is a non-pro saw, and won't actually cut wood.
For the most part yes, weather plays the biggest factor in that…but if you have to make a running shot and by chance end up gut-shooting ‘em you need to get the guts out of ‘em quick-like.I don't hunt nor do I have any real interest in doing so, but my understanding was that you gotta gut the deer right away or it will spoil the meat.
I'm a non pro tree cutter so that seems about right for me.According to the saw gurus, the 039 is a non-pro saw, and won't actually cut wood.
don’t think so unless half the parts are missing off the huskyThat 039 weighs as much as that 288
NopeSo from an anchoring point of view you reckon pretty similar Dave? Thoughts @dall?
But those have cut more than any other sawsAccording to the saw gurus, the 039 is a non-pro saw, and won't actually cut wood.
thought you was a sniper ?For the most part yes, weather plays the biggest factor in that…but if you have to make a running shot and by chance end up gut-shooting ‘em you need to get the guts out of ‘em quick-like.
290s and 390s all people use down here and they can certainly take a beating with the idiots I’ve seen run themBut it's too heavy for the power it makes.....and the sideways balance is skewed. Can't actually be used to fell trees.
only in the north eastBut it's too heavy for the power it makes.....and the sideways balance is skewed. Can't actually be used to fell trees.
Well somebody better recommend what saw i need to get some tree's on da ground. @dall i know you have a opinion on this subjectBut it's too heavy for the power it makes.....and the sideways balance is skewed. Can't actually be used to fell trees.
here too my first was a 310 that never failed me and I still have it290s and 390s all people use down here and they can certainly take a beating with the idiots I’ve seen run them
keep cutting slackerWell somebody better recommend what saw i need to get some tree's on da ground. @dall i know you have a opinion on this subject
You "friend" gotz all the good toys. Two post lift and a mini Bobcat Excavator. I'll bet he smokes cigars too John.Another 039 confirmed kill. View attachment 299275
Hell of a good firewood saw
