Wonkydonkey
Plastic member
- 8:54 AM
- May 14, 2017
- Sussex, UK.
Not specifically on this Genesis attachment. The machine is running at just over 5500 psi. It will munch a 10-12" bridge deck to pieces very easily Todd. I did have it stalled on 24" material but to me that is hydraulic hammer territory.Serious set of jaws there Tim how many lbs per square inch will it crush
Nothing anyone did. Just 1940s junk that breaksYeah hope you get it sorted out soon I bet the boss wasn’t to happy![]()
That’s any bord operator when *s-word hits the fan look lol most of the time that’s an awesome job whenever things are cooking along smooth. But boy whenever there is trouble those guys are extremely stressed out. Kudos to you for handling it well!So this Boiler trip.
My inside job has three 43bar Stork HP boilers as part of my responsibility.
Had to change fuel from fuel oil and fuel gas to just fuel gas. Outside guy shut correct valves at correct time, all groovy. Then an alarm sounded and the emergency low pressure fuel safeguard activated.
So no fuel at all now.
So the down wiggle top right trend box is the total refinery steam pressure. Got down to 38bar from 43.
The boiler output that tripped lower left. The other boiler picking up some load lower right.
Had liquid fuel fires back in within 5 minutes and then sent someone to check what went wrong, all the time wondering if it was a mistake on my part. Outside guy found a wire hanging out of a termination box. Clearly broken previously and never reported. Vibration from fuel change must have shaken it loose therefore 'zeroing' instrument.
Had our favourite instrument guy remake the lead and carried on with the job.
I made this face.
Refining. 99% boredom, 1% terror.
42° going up to 71° here. Typical Michigan weather. You go from swap ass highs to needing a hoodie or jacket in the morning 2 days later.Morning folks…a nice 64 this morning heading to 90 and clear.
Had a nice layer of dust on the Harley when it was over. Chilly ride home but totally worth itI guess I can't call ya a slacker this morning John. I see you shook off the red clay LOL!!
how many acres do you bale
Probably as many as he cuts...
I thought cattle couldn’t eat clover?
Morning slackers. I start a new job today. I put my notice in at the hardware store last week and finished it out on Friday. Left on good terms but it was time to move on. I'll be doing very similar work at this new job, loading and unloading trucks, pulling orders, palletizing, banding and strapping, making sure things are safe to roll down the road on flatbeds. Lots of forklifting. Only now I won't be in a retail environment dealing with that kind of chaos. Probably mostly paperwork today. Wish me luck.
Man I wish I had a big enough chipper to just run the whole tree through. I use this liberally on spots that have likely come into contact with PI.Chip it![]()
Man I wish I had a big enough chipper to just run the whole tree through. I use this liberally on spots that have likely come into contact with PI. View attachment 298384
An overnight oxyclean soak does for the sap and PI oils on clothes and gloves.View attachment 298385
I usually avoid getting Poison Ivy despite frequently working in and around it.
Try that hand sanitizer with him. Works great for me.My grandson Jonathan is extremely allergic to poison ivy. He's had some horrible cases of it.
