cuinrearview
Handy dood
6:51 PM
Dowling, MI
Did you tell her you married a dishwasher? Lol. Mine isnt bad either. Over thinks things alot but she's a good woman and isn't out behind my back being a piece of *s-wordt so I'm thankful for her
I was ready to hit best answer after the first sentence.
beaglebriar
The Peanut Gallery
6:51 PM
Warren Center, PA
Isn’t one side or the other of the bracket slotted to allow some adjustment? I think the other end is some sort of ball joint, correct?
The track bar has a rubber bushing through a single hole (not slotted) on the axle side and a large tie rod end on the frame side.
beaglebriar
The Peanut Gallery
6:51 PM
Warren Center, PA
I put three quarters of an inch of drop in the TC. Now I'm sitting at 7° TC and 8° pinion. The pinion is pointing up unless my thinking is completely bassackwards??
Vibes aren't completely gone but they are greatly improved.
Agent Smith
Hack of all trades
6:51 PM
Northeast ohio
You wanna get pinion angle off the flats of the yoke or seal dust shield if its big enough and not damaged. You never know if that cover surface was machined exactly perpendicular to the pinion
beaglebriar
The Peanut Gallery
6:51 PM
Warren Center, PA
I'm going off Tom woods info. The flats/ bolts on the back of the housing are parallel to the yoke. So either will work.
