Stihl working Hard
Is it Friday yet
- 3:32 PM
- Feb 6, 2016
- Perth Australia
Evening Randy any more news on your sick friendsSlackers !!!!
Evening BrettGood evening fellas
Gotcha.No it has the Chrysler 8.25 rear which has the shortest drive shaft of any of the XJ's. Makes the angle quite steep so I'm going to drop the transfer case some to compensate for now. Then go with a double cardan shaft to fix it proper later on.
Mainly log roads while hunting and mountain rides, nothing crazy. I don't think the drop will be an issue that way. Just worry about causing issue with the front DS.No shame in a case drop. Those factory skid plates are an anchor though. Where are you wheeling DJ?
FixedProlly out to dinner with his boyfriend @DuratecMan10
Pinion is 8°, transfer case 5°, drive shaft 18. I have considered trying shims.Whats your pinion angle look like? Sometimes on lifted vehicles it helps with driveline vibration if you use angled shims on the leaf spring pads if thats what you have. Could be a cheaper option
Ok, so what did you "lift" it wif?I never lifted any of my XJs, but the motor mount lift in my TJ was a game changer.
How are you doing TimWhat's up stranger.
The YJ "spacer" was just 2 pieces of 1" square tubing they drilled holes in for the new bolts to go through. I havent checked any angles, since it ran out smooth.Pinion is 8°, transfer case 5°, drive shaft 18. I have considered trying shims.
How are you this morning Todd?Not that moron![]()
Yup hopefully that's all it'll take. Bigger tires will happen after I use up these 235's.Gotcha.
YJs are pretty short. Rough country kit came with a T case drop spacer and new bolts. That'll probably straighten it out getting that angle down. You'll like it once its not rattling your fillings out. Then you'll have to get taller tires. Maybe not HAVE to, but you'll WANT to.
Covid?My mailman and his wife are getting worse.
Not bad Brent going down to see my youngest daughter this morning with wifeyHow are you this morning Todd?
Is pinion 8° negative or positive?Pinion is 8°, transfer case 5°, drive shaft 18. I have considered trying shims.
That’s not good my friendMy mailman and his wife are getting worse.
Oh that sucks. Dont know am, but I'll throw an extra prayer up that way.My mailman and his wife are getting worse.
