Slumberjack
Team OPE benchwarmer
- 7:31 PM
- Nov 8, 2020
- Way down south Louisiana
Im compressed! Lol good yop buddy!
the outer dual was on the front when i bought it and i made them switch them to the back so i could drive it home 150 milesNice work bud. New rear skins in the plan?
and check the front end wheel alignment...the outer dual was on the front when i bought it and i made them switch them to the back so i could drive it home 150 miles
so i need to buy a matching set to put on the front and put the ones on the front back on the rears
155 each
compressed ? lol how big is she lolIm compressed! Lol good yop buddy!
Just big in da chest and bottom lolcompressed ? lol how big is she lol
yes i have a appointment next week for the 2 tires alignment and state inspection so about 400 bucks more thereand check the front end wheel alignment...
Your fine great grandpa. It will hold up under cruising.Amen.
Ed.....have you built many 4L60Es ? I'm wondering if I should try to beef one up, or start looking for a 4L80E.
Do start or end with your a dik or both?id call but id rather wait until you left and talked to the wife
i quit watching that *s-word years ago when they started doing that *s-word
why its all flat there
a little ice wont hurt anything
the yukon was covered in ice this morning tooj it running 10 minutes to clear the windshield
hit it with a hammer see if it changes anything
lol even when it wasnt hurt
we are getting freezing rain now
yes
dont buy cheap
the monte is my newest one
I'd say your spot on Ed. The input shaft gives up around 600hp or 520ft lbsBeen in a bunch of them, but its been a while and all were stock rebuilds/repair.
Sun shell is a weak spot, servo and sprag can all be bettered with quality parts though.
How much hp are you planning to throw at it?
I'd be ok with up to 500hp in front of one with good parts inside it, quality torque converter and a good/large cooler.
The planets don't like shock loads and nasty shift kits with little low stall big converters. Back off the banging hard shift and they do just fine. You can add clutches to soften the hit from gear to gear. The 80 shifts like mud imo but it will last longer under a beating. I did not put one in the 97' Z71 5.7 Vortec GMC pu with 3.73's when I broke hard parts backing up a steep hill/driveway with two cords on the car carrier and a face on the truck. I was on it in the mud and it hooked up the front locker on hard pack dirt, new tires 33" MT, boom. Lots of weight there on a very steep incline... all my fault. It had one and three left. No others gears. Drug it up ttt with his tractor to unload it. Replaced with a stock 150K 2000 2500 suburban trans that had the new t-case I did not use. It tows heavy logs sometimes pulling 8K.The planet carriers and one way clutches don’t hold much hotrod torque. The input drum also needs to be upgraded. I’d say big tires are 4x4 with a stroker 500hp is too much for a 4l60 all doable. But by the time you upgraded that. Kinda wish you had a 4l80 to start
Good. Kinda coasting right now. Over COVID. Got the call from the school today my daughter had close contact. It doesnt change my life too much but I'm bummed for her. Also won't get to hug her for 10 days. She works a lot harder than most of the *dipstick kids her age and that's the first thing she's pissed about missing.not warm enough
hows you slacker
Everyone rallying around that slacker now that he's finally posting pics of some work.Is Dallas doing any damn thing...been busy here today so I ain’t quite caught up. I’m sure his ass is paid his Sally Struthers, $19.95 dues for his Slack 101 diploma by now.
You said "push in".lol i usually have a ball hitch on anything i drive the lights except the license plate lights are rubber mounted recessed lights and will push in if i would hit something
you know youd do her too
lol you mean a signature ?Tea time
Do state or end with your a dik or both?
No issues 50K on it still bone stock. Trans was rebuilt I do believe. Suburban lost a head gasket and got hammered.
lol just the tipGood. Kinda coasting right now. Over COVID. Got the call from the school today my daughter had close contact. It doesnt change my life too much but I'm bummed for her. Also won't get to hug her for 10 days. She works a lot harder than most of the *dipstick kids her age and that's the first thing she's pissed about missing.
You said "push in".
NiceGood evening fellas. The crawler runs, and everything works. Just some small stuff left to do now.View attachment 283041
evening slacker why is the brake hose so long looks like it would get in the tire in certain timesGood evening fellas. The crawler runs, and everything works. Just some small stuff left to do now.View attachment 283041
Articulation bruhevening slacker why is the brake hose so long looks like it would get in the tire in certain times
Hit that ass ten ways to hell...lol i usually have a ball hitch on anything i drive the lights except the license plate lights are rubber mounted recessed lights and will push in if i would hit something
lolThe tip Sally.. just the tip
lol i would have ran it down the arm with that much travel the hose could catch a stick or rock and then it would be *f-wordedArticulation bruh
lol i knew we was on same pageHit that ass ten ways to hell...
Lol I was just making a joke, sorry it didn’t land well, but was there a reason you felt the need to insult me?where are you getting your information ?
you couldnt carried my lunch when i was your age and i doubt you could even yet
just because i dont post videos of everything i do or tell everything doesnt mean i sit on the couch everyday
When it's flexed wheeling there is no slack in the line. It has 12 inches of travel, so the brake line has to be long.evening slacker why is the brake hose so long looks like it would get in the tire in certain times
