full chizel
¯\_(ツ)_/¯
- 1:04 PM
- Sep 12, 2019
- USofA
I’d moveI found a nest of chiggers.
I ain't missin sh!t unless my rig lets me down in the way up.Prolly better wear your athletic supporter. Ifn you spackle them saggy ol bawls tew the deck you'll miss the gtg...
With enough moneyI wanna see Duratec shine...and I think this is a fine way. He can actually start posting up some pie pics...he’ll be knee deep in that *s-wordt in his travels!
I have a snotty lil mini mac 6. I sold the later version with that gawd awful break in the way of the frickin caps.Well after a few frustrating hours Red is dead(bad carb and oiler pump diaphragm).
Parts would be more than its worth(unless I find a donor). So I'm going wif yellow instead. Needs a carb clean/kit and fix the oiler pump check valve.
Shes minty other than that.
I know, its a Mini Mac...
Does it have the toggle switch or the stupid rocker switch? The rocker switch ones can get grounded out with crud in them. Best to unhook and try.theres one in my building that belongs to another guy i cant get spark out of so i know what your going through
From The Tribune staff reports
TRUSSVILLE — The Trussville Police Department is investigating after they said a woman slammed into the Home Depot in the Promenade at Tutwiler Farm shopping center. The woman drove through the doors with her car, took merchandise and fled the scene, according to police.
The incident happened on Friday, Aug. 14, 2020, around 9 a.m. Police said the woman staged items towards the front of the store, drove through the doors and picked up the items. A video showed the woman driving around inside the store in a black 2000 Pontiac Sunfire. The car has a Alabama disabled veteran tag #DV83J33.
lol toggle and have tried unhooking the shut off switchDoes it have the toggle switch or the stupid rocker switch? The rocker switch ones can get grounded out with crud in them. Best to unhook and try.
Also, coil to flywheel air gap should be .015". Spark plug should be .025". Points(if its got em) should be .015". Hardest part about these and Mini Macs is you hafta take it ALL apart to adjust ANYTHING.
Boil the pump diaphragm in a mix of wintergreen oil and water. It will fix it if not cracked. I did it to one of the saws I gave the bubba.Dis one. XL.
Has the Zama C2S carb. No primer. No auto oiler add on like later ones had. The only parts saw I have is a Super2 with all the primer stuff on it. View attachment 255146
Clorox bath there buddy.I found a nest of chiggers.
Unfortunately for me, I like STUFF.I may have stuff
Id rather work on one than a power mac 310 or trying to install a choke linkage in a Homelite 150. That mfer about hit the trash can. Had to go away for a day.Does it have the toggle switch or the stupid rocker switch? The rocker switch ones can get grounded out with crud in them. Best to unhook and try.
Maybe some Alum for dis one. Its more stretched out Dan my exes coochie...Boil the pump diaphragm in a mix of wintergreen oil and water. It will fix it if not cracked. I did it to one if the saws I gave the bubba.
Solid
Bring it North. I'll give it a home.lol toggle and have tried unhooking the shut off switch
not worth me messing with anymore
Coils on those can die.lol toggle and have tried unhooking the shut off switch
Thats good to know Gunner.Do yourself a favor and use this under it.
It will allow the solid color to expand and contract with the wood. If you don't use it you will be redoing it every three years trust me. Get a hold of the company and wait. It will be well worth it.
I've done more decks than I care to remember.
I've used this on new,old, peeling doesn't matter. You typically only need one gallon for a deck use only on the horizontal surfaces.
its not mine or it wouldnt be hereCoils on those can die.
If he dont want it anymore, I can give him a little bit and maybe send it down here. Just aint gonna put much in it. They are fairly common here.
so you are a painter of houses ?Do yourself a favor and use this under it.
Caught a nice mess of bluegills last weekend.Thats good to know Gunner.
I'm replacing two decks here as I get time and money.
I'll try that. Cant hurt.
Hope alls good out your way.
Hows the fishing?
Yah. Bofe of dose is DAMMIT saws...Id rather work on one than a power mac 310 or trying to install a choke linkage in a Homelite 150. That mfer about hit the trash can. Had to go away for a day.
