Slumberjack
Team OPE benchwarmer
- 11:40 AM
- Nov 8, 2020
- Way down south Louisiana
I like pie@Slumberjack loves blowing bubbles
and blowing bubblesI like pie
lol i still call you slacker
Mehand blowing bubbles
I know you’re gonna miss me but I’ll be back sweetieand blowing bubbles
cant blame youdid that all day at the farm.
cant blame you
You is about right slacker.how high does that lift cart go or am I wrong on what it is
the overhead cranes at work are probably close To 50 feet off the floor and the ones in your pictures look like they would fit between the cross beamsYou is about right slacker.
Its called a Trilifter.
It can lift a load strapped to the top, and it has a boom that extends from both ends, so it can lift from the floor as well. The rear axle assembly is also on slides, so the wheelbase can be extended for more lifting power and stability.
I believe the lifting height on the deck without the extension is around 25'.
They have the first 6' extension on to get to the crane thats at 30'. They can stack extensions to get higher, but it leaves the load further off the floor when lowered, if that makes sense.
The 4 lifting cylinders are telescopic multi stage units. Flow and pressure can be manually biased to each cylinder to compensate for slight load imbalances too.
Shes good for lifting 75,000 lbs. Got a Ferd 460 that runs on propane, so shes got ALL the hearse purrs.
how’s you slackerEvenin, fellers. You too @dall.
Don’t like reading about all the losses and sickness. Sorry about your friend @stihl livin.
Hope you and the mrs get to feeling better @Mastermind
I’m ok. Getting sleepy. Only 3 more hours before bedhow’s you slacker
I’m a night owlSay what 3 hours?
that’s how he makes the sausageSay what 3 hours?
