Slumberjack
Team OPE benchwarmer
- 9:15 PM
- Nov 8, 2020
- Way down south Louisiana
Very nice! Me likely!Stumpshot ported 268View attachment 266836
Boss eye ain't had much problem putting my boring bit in a blind hole.........[emoji1787]It's a tricky operation doing a facing cut with a boring bar in a blind hole, but once you get comfortable with it, you'll wonder why you avoided it.
5 angle valve job and installation of springs as well as shimming them for the proper spring height and pressures sounds like as well for over .500 lift you gonna run with them 1.7 rockers. You will wish you did if you didn’t lol. The dual plane will keep plenty of bottom end wink wink!No sir.
The heads won't be here till the 20th. Then they will have to be port matched, and sent to the machine shop to be printed, and have studs and guide plates installed.
2 spikes, 1 fork horn, 8 doe and a very large coyote which eye passed on. Should have just shot the bastage.Any deer over there today?
Main Crank journals on a 351w are huge!
You probably already know but pulling the valves and blending the runners into the seat makes a huge difference too!No sir.
What is the lobe sep centerline in that cam 110 deg or 112?Well....just a 3 angle valve job. Total lift will only be about .475, but we're using dual springs with dampeners, and Comp Cam 10° retainers and locks.
I knew you would be hahahh we sprekins the same lingidy!I'm all over that.....like a fat kid on a cupcake.
I'll have to double check....
I guess they don't call you hot rod for nothingBoss eye ain't had much problem putting my boring bit in a blind hole.........[emoji1787]
Cant say I ever avoided it either [emoji6]
No sir.
afternoon to you again mr. pioneer!Good afternoon fellas.
You can have some of ours if you like? HahahhSun showed up.
When will it be ready to hit the dirt circle track?
