SOLD Nice Husqvarna 394XP
srcarr52
12:40 PM
Iowa City
What the difference between a 394 and a 395, other than the porting,
394 - 395
dual - quad transfer ports
plastic intake block - rubber intake boot
internal pulse through manifold - external pulse
solid mounted carb - rubber isolated mount
walbro - tillotson carb
low top or HD high top filter options - only HD high top
large crank flywheel snout - small flywheel snout
separate key flywheel - cast in key in flywheel
hseII
Heef
12:40 PM
West Georgia
Quad port vs dual port.
Engrish not yo firs language, no?
394 - 395
Thank You for this detailed, clear, and concise explanation of the differences between the 394 & 395.
VinceGU05
one day when i grow up...
12:40 PM
S.E Australia
On the rear of the tank those are limiter pins. There are two options per side for their location, on the bottom allows more movement in the AV, or higher up on the chassis which goes into a hole in the tank which is less movement.
now i know where those left over screws go!!
Wood Doctor
Edwin
11:40 AM
Omaha, Nebraska
This is the only saw that ever beat me at a GTG while running a Stihl 084. Both of us had 36" bars on board. I was running stock and 404 chain and he was running muff modified and skip tooth chain. He nipped me on both sides of the log. Needless to say, I was impressed with that thing. Nobody else there could touch either one of us but he cleaned my clock to take top eliminator.
rattler
12:40 PM
NC
Good deal Ted.
Sent from my XT1060 using Tapatalk
