Warped5
- 5:51 AM
- Jan 7, 2016
- Northwest IN
Quad port vs dual port.What the difference between a 394 and a 395, other than the porting,
394 - 395
dual - quad transfer ports
plastic intake block - rubber intake boot
internal pulse through manifold - external pulse
solid mounted carb - rubber isolated mount
walbro - tillotson carb
low top or HD high top filter options - only HD high top
large crank flywheel snout - small flywheel snout
separate key flywheel - cast in key in flywheel
now i know where those left over screws go!!On the rear of the tank those are limiter pins. There are two options per side for their location, on the bottom allows more movement in the AV, or higher up on the chassis which goes into a hole in the tank which is less movement.
Have at it my friend .Bump for a grateful dead groupie....
My gawd it's a nice saw... I got a 395 tho....
Can I kick the tires since Skippy ain't here?
everybody must be as broke as me. No other good reason for this saw to still be available.
