PDX Man
OPE Member
- 10:11 AM
- Jun 25, 2017
- Portland OR
I am pretty inexperienced with engines, but I'm trying to fix my splitter's GX240 myself anyway. I've tried the easy stuff I can think of and am looking for ideas on what could be wrong and what to try next.
The background: It was running OK, maybe a bit hard to start, but it ran OK. Then it started stalling out when running. I could start it and it would die in a few minutes. Then it just would start with choke, but die as soon as the choke was opened.
I've disconnected the oil shutdown, so it isn't that. I've tried loosening the fuel cap to see if the vent was blocked. I've tried removing the air filter to make sure it isn't a clogged air filter. I've replaced the spark plug, the fuel filter and fuel line. I got a new chinese carb and tried that. It behaves pretty much the same. I'm not sure if those carbs are supposed to come properly adjusted. I saw reviews of the carbs on amazon that say they just bolted the carb on and it worked, so I'm assuming they come adjusted at least approximately. And it behaves pretty much like the original carb, so I'm thinking it is not the carb.
I've noticed now that it will actually run rough for a while if the throttle is set to idle, but it dies after a bit or immediately if the throttle is opened up at all.
I'd appreciate any ideas on what could be wrong and what to try next. Thanks in advance.
If it helps, I've put up some videos on youtube of how it is running now with the original carb and the new carb.
This one is it running with the original carb:
This is with the new carb:
https://www.youtube.com/watch?v=74qYKU7y6-w&feature=youtu.be
