New hobby/addiction
ErnieG
8:36 AM
Northeast PA
Anyone know what type of fuel this thing uses? Same as a lantern I'm assuming but not sure. I believe it's a very old type of road flare out of an 18 wheeler. Not 100% on that though.
I'm fairly certain you can burn citronella in those ..it's nice outside evenings to keep the bugs away .
Ernie
FergusonTO35
8:36 AM
Boonesborough, KY
That is a small smudge pot. They were used to produce a thick soot that attaches to fruit trees to protect from frost, and also used as road flares. Citronella would be a good choice, but you can burn just about any type of fuel oil in it. I think a mixture of diesel and used motor oil is what was used for smudge.
ErnieG
8:36 AM
Northeast PA
Yesterday my GF and I were in the big city and scored a brown lantern for free from a pawn shop.
Today my GF comes home with these.
Two brown ones in two days.
Can’t remember when I saw a brown one last. View attachment 460933
Those easi-lites are great lanterns !
Old Coleman parts sells the o-ring rebuild kits for those lanterns just fyi
Ernie
FergusonTO35
8:36 AM
Boonesborough, KY
I got them cleaned up and inspected. It appears that one has good enough sheet metal not to be a fire hazard and there are enough parts between the two to make one good lantern, and maybe a decorative piece with the other. Hopefully I can make it happen this spring. Thanks again!
I've also found that Rust Oleum flat black rust converter primer works great for lanterns. It is fairly fuel and heat resistant and makes a nice old-looking patina. A lot of lanterns and stoves were painted flat black back in the day so it is a restoration correct finish in many cases. This would include most tubular lanterns and railroad lanterns. In fact I think some "economy" single mantle Colemans were painted flat black, I remember us having one as a kid.
cuinrearview
Handy dood
8:36 AM
Dowling, MI
I picked up a real nice looking 275 at a sale this fall with an extra picket fence globe if anyone is looking. No case.
legdelimber
8:36 AM
N.C.
Been a long time since I've seen one of those with the tubes routed back into the burner. Does anyone know what to call that type of lamp? As a kid, I always thought that they burned a little brighter and perhaps cleaner?
Could you, safely, run alcohol or a blend of alcohol and kerosene in one?
Santa was good to me again this year, brought a very nice English made Chalwyn Pilot hot blast lantern. Gonna see if I can get it going!
FergusonTO35
8:36 AM
Boonesborough, KY
As far as I know, kerosene and lamp oil/paraffin oil are the only fuels that a wick lantern are intended to use. The biggest problem with alcohol is that it's hygroscopic and draws moisture from the air. Meaning, not only will the fuel be contaminated but the metal will corrode pretty quickly. The Chalwyn design is called a hot blast lantern. Supposedly, the heat from the chimney pushes air through the tubes and into the burner producing a cleaner and brighter flame. Most Dietz lanterns are the cold blast type, where the air tubes are indirectly connected to the chimney on the sides, with the heat pushing cooler outside air into the tubes. Railroad and signal lanterns without tubes are called dead flame types, the only oxygen the flame receives is through the vent holes around the burner. These lanterns were intended more for signaling than to actually provide illumination, and so making the lantern simple, rugged, and compact was the primary concern. See my previous post with my Adlake C&O railroad lantern.
legdelimber
8:36 AM
N.C.
Ferguson, Good point on the water and alcohol issue.
You'd think that as a regular complainer about corn-gas, I'd have caught myself on that with the metal lanterns.
Thinking back a few decades (when/how did i get that old? :eek:) I do believe the alcohol was always in one of the glass type "table" lamps.
I have light sensitive migraines and sometimes I'd just like some none flickering light in the house. The heat output (indoors) would kinda limit flame lights to winter time though.
LED lighting and televisions (especially cellphones) can be pretty rough to be around, when I'm having a bad migraine.
FergusonTO35
8:36 AM
Boonesborough, KY
I don't know that alcohol is necessarily unsafe in wick lanterns and lamps, after all it is used in small and flimsy wick burners for keeping food warm. It would cost alot more than pump kerosene and attract moisture. I have used my wick lanterns and lamps plenty indoors during spring and summer storms, and never found the heat output to make the temperature go from comfortable to uncomfortable. However, I may not be as sensitive to it as some folks. The smaller 1/2 and 5/8 wick lanterns do produce noticeably less heat than the bigger 13/16 and 7/8 wicks while still providing enough light for reading or whatever you need to do.
