morewood
Mr. Awesome
- 12:47 PM
- Mar 11, 2016
- Old Fort, NC
Looks great. What was the heck in the hand basket issue? I’ve been looking at those for a few years now for my John Deere for cutting firewood poles to save on the old back. I’m anxious to hear how it works for you. Thanks for sharing.
I have a JD 5000 series. No doubt they have mounts for that as well. Our tractor doesn’t have the loader operator handle like yours I can operate up down & curl in & out with ours that’s it. I have an extra lever next to the tractor seat that operates a 3rd remote running to the front of the tractor. We use it to operate the angle on our snow plow & to open & close the clamp we have on a set of forks for holding logs while I cut them. It’s extremely hard for me to judge where the forks are when I drive into the log pile. Your frostbite looks like it would be easier to grab logs individually. It would also be nice to have all the hydraulic remotes on one joystick like you have instead of 2 separate levers.The whole economy tanking. While I may be getting my hours, I'm not getting my gravy hours...... overtime. I can't complain, we have our jobs, everything but the car is paid for, money in the bank.
We're in the same boat. I'm bringing the logs down in 9' sticks to work them up at my own place and on my own time. I don't plan on cutting much on the ground anymore either. This one came with JD 400 series mounts. I'm getting a set of 'fingers' made to bolt to the ends of the forks. They'll only extend an extra 4-5" but should come in handy. They'll also be painted a gaudy bright neon color so that I'll always be able to see them.
Mr Awesome
I have a JD 5000 series. No doubt they have mounts for that as well. Our tractor doesn’t have the loader operator handle like yours I can operate up down & curl in & out with ours that’s it. I have an extra lever next to the tractor seat that operates a 3rd remote running to the front of the tractor. We use it to operate the angle on our snow plow & to open & close the clamp we have on a set of forks for holding logs while I cut them. It’s extremely hard for me to judge where the forks are when I drive into the log pile. Your frostbite looks like it would be easier to grab logs individually. It would also be nice to have all the hydraulic remotes on one joystick like you have instead of 2 separate levers.![]()
Thank you sir!I added a diverter valve just like Mr awesome. I used this one, though there are lots of options.
http://www.boltonhooks.com/hydraulic_valves.html
It was about $300 for the valve and adapters and another $100 in hoses.
I have a similar grapple. It is way better for handling logs than my root grapple. I cut firewood out of it. It comes in real handy when you get a small diameter crooked log, it is way better than cutting of the ground. I cut on one side and my dad cuts on the other side. Then when we are done cutting we have a pile of rounds versus rounds scattered everywhere from cutting on the ground.
