New cbn wheel, bad vibration.
Khntr85
8:58 AM
Indiana
That's good... I just got a Oregon 520 I love it, better than I thought it would be.....eventually I will get a CBN... have you been grinding for a long time??
Chainsaw Addict
GO HOOSIERS
8:58 AM
Indianapolis
Just 5 or 6 years. I just change chains when cutting and sharpen after dark. I use a Harbour Freight digital caliper when changing from left side to right to get same cutter size. When chains get worn down or rocked, I set them aside for stump or crappy cutting. I use an old plastic chainsaw case for chains, tools, wedges. I keep chains in ziplocks and label with painters tape an sharpie. Once used I mark dull my on label. I also spray a bit of WD on chains while in bag.20161122_181542.jpg20161122_181607.jpg20161122_181659.jpg
Sent from my SM-N900P using Tapatalk
Chainsaw Addict
GO HOOSIERS
8:58 AM
Indianapolis
Just 5 or 6 years. I just change chains when cutting and sharpen after dark. I use a Harbour Freight digital caliper when changing from left side to right to get same cutter size. When chains get worn down or rocked, I set them aside for stump or crappy cutting. I use an old plastic chainsaw case for chains, tools, wedges. I keep chains in ziplocks and label with painters tape an sharpie. Once used I mark dull my on label. I also spray a bit of WD on chains while in bag.View attachment 41775View attachment 41776View attachment 41777
I also mark if chain new, good, 1/2, or rock.
Khntr85
8:58 AM
Indiana
Nice set up there, now that I am acquiring more chains I need to start getting more organized.... I constantly have a chain/bar and the seat of my truck lol....
I do need to get me a cheap/decent caliper.... is the harbor freight one decent.... a few guys told me to use a little adjustable wrench if you dont have calipers...
Philbert
Chainsaw Enthusiast
7:58 AM
East Dakota
Don't buy a plastic ('polymer') caliper - they flex so much that the reading can be whatever you want it to be. Cheap, digital, metal caliper might be OK.
I just hold cutters back-to-back and eyeball them.
Philbert
dannyupsolate
8:58 AM
hawk pride alabama
learn the feel of your caliper get a ground dowell pin test it over and over till you get correct result over and over. I can do it with 36 inch electronic calipers. you can to with practice. if not throw them in scrap pile and try another caliper
Khntr85
8:58 AM
Indiana
To OP did you get any results yet???
Cutforfun
5:58 AM
Palmer mill
Diamond wheel was not much help. They said I can send it back and they will refund my money. Not the resolution I wanted. I don't have a problem sending the wheel back, but would like to know the problem, is it my grinder or a bad wheel. I really feel that the wheel has a thick spot with the plating. Not sure what to do?
Moparmyway
Its just a saw
8:58 AM
In a meeting
Send it to me and I'll give a good look, if you want
Khntr85
8:58 AM
Indiana
I know its would be a pain in the ass, but honestly you probably will just have to send it back..... since there is no real way to true the wheel....
I mean if every wheel you put in the grinder does that, then that's were the issue may lie... hate to hear this problem....
Khntr85
8:58 AM
Indiana
Please keep us updated!!!!
Khntr85
8:58 AM
Indiana
Well did you end up sending the wheel back???
Cutforfun
5:58 AM
Palmer mill
I still have the wheel and I am going to keep it, I wish Diamond wheel offered to send a new wheel ,if I sent this one back but they did not(the offered a refund ,but did not want to help). I ground a few really messed up chains and dressed the wheel a handful of times. It seams to be getting better. I still think the plaiting is thick in one spot causing the vibration. If I lower the wheel to just kiss the tooth, it hits only in one spot every rotation. I will try and keep you posted the more I use it.
Khntr85
8:58 AM
Indiana
Ok good deal.... let me ask ya this, do the stone wheels do the same thing on your grinder???
super3
8:58 AM
Indiana
This^^^
If you keep running it like it is without determining if it is the wheel or the wheel mount you will eventually take the bearings out of the motor.
