Need help with ts400 stilh concreate saw.
jim thompson
New OPE Member
4:43 PM
brinston , ontario canada
This saw runs fine hot , but when cold have to pour gas down spark plug hole. Starts great hot but sets is a no go any ideas , new carb kit cleaned out everything ???
4:43 PM
The seals are probably bad and it's lost most of its pulse to run the pump in the carb. Or it needs new impulse and fuel lines and filter.
I have the same saw. 17 pulls on choke to get it to fire when cold. It's now awaiting a full rebuild
Junior Samples
4:43 PM
Richmond Ky
What he just said. But what I have found because I work on all the neighbors saws and weed eaters I went to HF and got a ultrasonic parts cleaner and two rounds with that and new diaphragms and there ready to rumble. Something clogging things up.
Mark Caldwell
4:43 PM
Virginia
I just bought the same saw (TS 400) and the piston was blown up. So a quick question the connecting rod has some side-to-side play on the crane needle bearing (you can feel it at the top of the connecting rod if you know what I mean). Do you think I should replace the crank as well?
