Need help with a 064. which ignition to use?
Ladrhog
12:51 AM
PNW
Ok so I have a few boxes of parts for 064/066 saws. I decided to put a 064 together. Everything was going great until I got to the ignition. Looked in the box and there wasn't one. I have a few coils for 066/064 and I don't know what to use. Here are the three I have
The two flywheels I have end in 1201A and 1203. I have another case and the both have the 3 screw holes. On case it looks like used the top hole and the other the bottom. I am confused. will one of the coils work. I also have a limited red light coil but I don't want to use it.
Thanks in advance
Ladrhog
12:51 AM
PNW
Here is a pdf I have of 064 coils. I don't really know how to tell what I have
Ladrhog
12:51 AM
PNW
I have been doing some research on AS but all the pictures are gone from the old posts
Ladrhog
12:51 AM
PNW
That helps but I am still having a hard time Identifying coils.
Gunn
Yay sawz
2:51 AM
Plover wi
The flywheel will determine which coil you must use. Based on your picture you have the 1201 Fw which is unlimited (desirable). This means you can use the 1122 400 1300 coil. Some of the 064 crankcases also had a dual mounting pattern to also work with the 000 400 1300 coil which was used on a *s-word load of saws.
Canadian farm boy
“Normal” people scare me.
3:51 AM
Ontario, Canada
All I can tell you is that from the pics you posted the coil in the middle is for an 066 with a poly flywheel.(1314 coil) It also works on other saws. I believe it won't work on your 064.
Ladrhog
12:51 AM
PNW
One on the left
The right
Which would work with a 1122 400 1201a flywheel
Ladrhog
12:51 AM
PNW
One of my coils is a bosch
